Old 04-29-2017, 03:41 PM   #1
07 Carrera S Cab
Boxtaboy's Avatar
Loose intake/plenum boots?...
I had my engine cover off today to replace the engine air filter (something I hadn't done in a few years), and so I figured I'd tighten up the metal hose clamps at the intake/throttle body/plenum connection. I found one of them (the inner lower left boot connection clamp) was tightening too much (the boot slipped off at the bottom), and so there was a gap. All other connections were solid. I was wondering why the car felt a little sluggish under full acceleration and I guess this was why. Once resealed, the car had its power back. Maybe worthwhile to check these connections once in a while...
Old 04-30-2017, 06:58 PM   #2
1997 Tip, 2018 Macan
rexcramer's Avatar
Any idea how long it was like that? And you didn't get any codes? I would think all that air bypassing the MAF would trigger something.
Old 05-01-2017, 06:10 AM   #3
07 Carrera S Cab
Boxtaboy's Avatar
The last time I cleaned my throttle body was 7 years ago, and that's when the plenum boots were loosened and redone. I noticed the sluggish acceleration about a year and a half ago, but didn't think much of it cause I always thought the 2.7L was supposed to be slow anyway...LOL. I also hadn't changed my engine air filter in 7 yrs cause I only put like 5K miles on it or so, hence why I never took my engine cover off in all those years to check. I am thinking the MAF wouldn't detect it cause it is located right after the air intake box. After it flows past the MAF, it goes into the throttle body, and then after the throttle body, it goes into the plenums. Someone correct me if I'm wrong.
