Old 04-17-2017, 04:48 PM   #1
Yet another locking/alarm issue
So I searched and searched, and see many people have issues with the central locking mechanism. I thought I've narrowed it down to the immobilizer unit (and maybe it still is part of the problem). When I pull the codes, I get the following long list of codes:
Fault memory
49
K lead
48
Airbag signal acknowledged
21
W lead (DME immobilizer)
42
Wrong key or wrong transponder pill
33
Passenger compartment monitoring sensor
23
W lead
47
Control locking synchronization
46
60
Central locking limit position Lock not reached
I'm hoping it's one problem that's cascading onto multiple codes (I know airbag points to driver's side belt buckle, which I'll deal with eventually...)
When I attempt the manual override (quick 3 turns clockwise on driver's side lock), the driver's side locks, but not the passenger side. When I open the passenger side door, the blinkers flash rapidly, which turns off when I unlock the driver's side door and open it. The trunk unlocks every time without a problem. And every time, I hear the gas cap attempting to lock, and reverse itself when I press the lock button on the keyfob.
I'm wondering if in addition to the DME issues, I have door lock mechanism issues on passenger and/or the driver's side?
It's kind of like information overload at the moment. I'm hoping that someone experienced can chime in and see if there is a logical process I can go through to narrow down the problem, before I cry uncle and take it to a shop!
BTW it's 98 base boxster...109K miles.
stanigu is offline   Reply With Quote
Tags
central lock , dme , lock , remote , remote locking
