Old 06-28-2006, 09:22 PM   #1
omg what is this noise?!
i have a really loud howl coming from my fuel filler area. Anyone know what this might be? Fuel pump? It definitely sounds like some sort of bearing noise. It happens only when I'm stopped as far as I can tell. I can't really hear it when driving.
oversteerdawg is offline   Reply With Quote
Old 06-30-2006, 02:09 PM   #2
deliriousga's Avatar
It sounds like the cooling fan bearings are wearing out on that side.
1966 Wife White/Brown Top
Old 06-30-2006, 02:41 PM   #3
Does it happen at start up and stop as the car warms up?
Old 07-01-2006, 11:39 PM   #4
after listening more carefully, it's actually a sucking sound.
Old 07-02-2006, 02:22 AM   #5
Almost like a high pitched vacuum?
Old 07-02-2006, 06:06 AM   #6
Try filling your car up with gas. Did the noise go away? Then it's the fuel pump. The pump is in the tank and is noisy and hot when the gas is low. The gas in the tank helps to cool the pump as well as keep it quiet. When the tank gets low you can hear it wine.
You should hear a Walbro 255LPH when the tank gets low, it's retarded sounding. (thats a high performance fuel pump for high hp cars 400+)
986Jim is offline   Reply With Quote
Old 07-17-2006, 01:57 PM   #7
That's exactly what it sounded like. I replaced the fuel tank purge valve and the noise and CEL went away. I few days later, both the cel and noise is back. Anyone?
Old 07-17-2006, 02:12 PM   #8
I just got used to it. Although I think mine has to do with a part that warms up the exhaust system,I cant remember exactly what. It goes away as the car warms up after about 5 minutes or so and stays off as long as the car is warm.
Old 07-17-2006, 02:27 PM   #9
There is a post on pelicanparts that suggests that it may be a leaking bleeder valve on the fuel filler (#12 in the pic)
Anyone try this fix before?
Old 07-17-2006, 02:27 PM   #10
Perfectlap's Avatar
is this the weezing sound that comes when you get on the throttle from a slow start or standing start? I've noticed that lately, I've been very bad about not letting my gas tank go below 1/4.
THe sound drives me nuts but I like the feel of the car when its light on fuel.
No kidding.
Old 07-17-2006, 02:45 PM   #11
No kidding.
It's exactly like blinkwatt says; a high pitched sucking noise coming right from the fuel filler area. It happens at any fuel level and temp. It goes away for a few seconds when i blip the throttle. It does not effect drivability, but it is driving me absolutely nuts.
Old 07-17-2006, 02:49 PM   #12
Perfectlap's Avatar
mine isn't coming from the gas cap area at all. Its coming from behind me near the the air intake. Same deal when I blip the throttle, weeze....
