Old 04-08-2017, 07:48 PM   #21
Pleased to say the ball joint separator that was recommended worked perfectly. I took the first one off and my son took the second. The driver's side sounded like a shotgun when it let go, the passenger's side was more like a .22. Both rear lower control arms have been replaced.
alex.rhodes is offline   Reply With Quote
Old 04-08-2017, 08:17 PM   #22
steved0x's Avatar
Awesome!!! Any other projects while you were in there or just the control arms? Always a good feeling with a job well done
Old 04-09-2017, 04:04 AM   #23
I was trying to get the transmission fluid changed and my younger son was cleaning road grime from the transmission and wheel wells. The fill plug refuses to let go and I've soaked it with kroil multiple times. I'm probably going to take it in for that one, let a profession take it out and verify the threads aren't stripped. Give them a chance to give everything a once over make sure it's in good health.
Really surprised my sons when the ball joint let go. If the nut was not still on I think it would have been embedded in the floor. My older son was able to install the control arms himself, I simply locked everything down.
Old 04-10-2017, 08:13 PM   #24
Glad to hear you had good luck! Did you grind the inside edge to 26mm+?
2001 Boxster
Old 04-11-2017, 04:46 AM   #25
No grinding. What should I have ground?
Old 04-11-2017, 05:33 AM   #26
steved0x's Avatar
Check out the U shaped jaws on my tool compared with Jake 's. The wider jaws allow the tool to get around the LCA ball joint better. Unground works too (I was able to do one side with the stock tool but it kept slipping off the other side) and you had good success too. If I had a grinding tool I would have done mine too.
Originally Posted by jakeru View Post
That tool looks very beefy, bird dog!
Here's my harbor freight balljoint tool, with inside u-shaped edge ground out to fit around the 986 balljoint's 26mm diameter. (Still works on 986 tie rod ends, too!) I have very little doubt that this tool will also last my lifetime.
Old 04-11-2017, 06:02 PM   #27
I used 2 pickle forks. One on top of the other. The yhad 2 at the part store and I couldn't decide on which one so I bought both! First one wasn't getting enough leverage so then I tried the second one on top of the first. Worked like a charm.
'99 Boxster Artic Silver/Red
'14 Subaru Outback
'06 EG Classic
'05 Sportster
