Old 04-02-2017, 06:14 PM   #1
Exclamation Thermostat Changed! Temp Gauge not working.
Swallowing some man pride,... I was an idiot. We moved to a resort in central Oregon and we had one of the coldest winters in years and my car froze. -2002 Boxster
The Good:
1. Changed the thermostat yesterday.
2. No leaking of coolant.
3. Cooling fans work.
The Bad:
1. Temp gauge not working.
2. No Heat.
3. Warning light flashing
- I replaced the water pump about 7-ish months ago.
Thoughts? or advice would be greatly appreciated. Please help!
About me: I'm no mechanic, but I've always done my own work big or small. My father was a master mechanic.
DrowsyJay is offline   Reply With Quote
Old 04-02-2017, 06:19 PM   #2
Sounds like you have an air pocket in the system, did you refill it under vacuum?
Old 04-02-2017, 06:23 PM   #3
I did not, bubbled and bled it. Would that explain the temp gauge not working?
Old 04-02-2017, 07:37 PM   #4
^^ What JFP said. Bleed it again. ^^
Old 04-03-2017, 04:43 AM   #5
Project Addicted
jcslocum's Avatar
It's on the opposite side from the therm so doubtful you knocked it loose.
Worth a quick plug and unplug.
______
Jon
1966 912, 1976 911
1986 944, 2000 Boxster
Tags
boxster , coolant , heater , warning light
