Old 03-22-2017, 04:40 AM   #1
1998 Boxster
Cam index notch orientation
Hi. I've had the heads off my '98 Boxster for a couple years and am finally putting it back together. While I've done a lot of reading regarding timing the cams, I often end up being just short of completely confident.
My question is about the orientation of the indexing notches on the
intake cams.
On bank 1- when #1 cylinder is at tdc compression, the index notch on the intake cam is pointing away from the engine....
.....then,
Where is the index notch pointing on the intake cam of bank 2. (meaning cylinder #4 is at tdc exhaust)
rah rah 986 is offline   Reply With Quote
Old 03-23-2017, 10:01 AM   #2
Porsche "Purist"
Paul's Avatar
DIY: Setting Cam Timing on M96
1987 924S. 2002 996TT. PST-2
Old 03-24-2017, 04:06 AM   #3
1998 Boxster
Paul, thanks for posting that link. I have read it many times and have found it to be the single most concise, useful, informative, easy to understand tutorial on setting timing that I have found. However, insite's write-up is timing an assembled engine. I am in the process of installing the cams into the engine and am asking specifically what the relationship is between the indexing notch on the bank two came relative to the indexing notch on the bank 1 cam. Insite's write-up perfectly shows the position of the notch for bank 1 in both tdc compression as well as tdc exhaust, but does not show the corresponding position of the notch for the bank 2 cam.
I've since learned from another poster on another forum that when properly timed, the notches from both banks will either both be pointing in, or both be pointing out...meaning, if the bank 1 notch is pointing out when the engine is at tdc compression for cylinder #1, then the notch on the cam for bank 2 will also be pointing out (away from the engine).
Can anyone concur?
