Old 03-14-2017, 01:26 PM   #21
itskenallen's Avatar
I came across this on eBay from Team 2 fast in Germany. I messaged thrm and they sent me a video clip. It sounded OK too.
https://drive.google.com/file/d/0B4YPkgkvt_XvZ3NuYVc2SThUZTQ/view?usp=drivesdk
Sent from my SM-G928F using Tapatalk
itskenallen is offline   Reply With Quote
Old 03-14-2017, 01:42 PM   #22
07 Carrera S Cab
Boxtaboy's Avatar
7hp at top end ain't bad. Better than losing hp which some of these aftermarket mufflers do!
Old 03-14-2017, 02:31 PM   #23
It's the same one that everyone sells under 40 different names.
bwdz is offline   Reply With Quote
Old 03-14-2017, 02:41 PM   #24
The Radium King's Avatar
rule of thumb 10 lbs = 1 hp? you loose 40 lbs with a full change (headers, no cats) - that's another 4 apparent hp.
Old 03-14-2017, 03:04 PM   #25
Possibly... But the price is dead right. Def worth trying at €250
Old 03-14-2017, 03:12 PM   #26
edc
550 Anniversary
edc's Avatar
If you really want these cheap they go for much less second hand on UK eBay and on boxa.net
Old 03-14-2017, 04:46 PM   #27
07 Carrera S Cab
Boxtaboy's Avatar
They are not all the same. They look the same, but the AP one in that video give you 23hp!
Old 03-15-2017, 10:05 AM   #28
heliguy's Avatar
Maybe they mean that you lose 23 lbs...
Old 03-15-2017, 12:30 PM   #29
Any improvement in weight is a bonus I suppose. That coupled with the sound makes it at least worth a try...
I also came across a full stainless set for €750 comprising of headers, cat delete pipes and muffler. Now that might be worth a try. Has anyone in the UK/Ireland removed their cats and pass emissions?
Old 03-15-2017, 02:50 PM   #30
edc
550 Anniversary
edc's Avatar
My 100cell cats went bad and failed the MOT.
Old 03-15-2017, 06:33 PM   #31
DarkStar's Avatar
Idk about this only gaining power in the near recline... I don't notice any power gains past 5500. It's mainly low and mid. But um also at 6k elevation so the car is easily smothered. Unrestricting air flow is a very good performance increase. You don't want backpressure, you want a good scavenging effect in a well built exhaust. The 986 exhaust design is extremely restrictive with tons of tight bends, small piping, everything about the factory is flawed.
Anyway here's another clip showing how quiet it is inside with windows up
https://youtu.be/RMLUB-8kcFA
-Josh
2001 Porsche 986 Boxster RS2.7 Bi-Turbo
DarkStar is offline   Reply With Quote
