Old 03-06-2017, 06:16 PM   #1
WillH's Avatar
Question Intake manifold movement?
Noticed what appears to be the manifolds moving away from each other as throttle is given. Or am I just seeing the throttle body moving upwards , (being held by intake tube), as the engine rotates to the passenger side in response to the torque?
Did I miss a passage about variable intake lengths that require manifold movement?
Old 03-06-2017, 07:27 PM   #2
If the engine is moving like that - have you checked the engine mounts?
Old 03-07-2017, 02:53 AM   #3
WillH's Avatar
Engine mount only has a few thousand miles on it. It's the normal amount of movement that I would expect to see on any rubber mounted engine and less than what you normally get with a v8. Are the manifolds flexible?
Old 03-07-2017, 06:37 AM   #4
01101
This happens on mine. The boots between the manifolds are rubber, and under vacuum they will contract.
alm001 is offline   Reply With Quote
Old 03-07-2017, 06:42 AM   #5
Will is saying that the intake manifolds are moving away from each other ?, this means that one of them could be loose, but if you have a worn engine/tranny mount both manifolds will move along with the throttle body (and engine..)
Old 03-07-2017, 06:48 AM   #6
01101
Right, moving away from each other under throttle. So as he presses the throttle manifold vacuum level goes down, and the manifolds move apart.
Old 03-07-2017, 02:58 PM   #7
WillH's Avatar
https://youtu.be/8_ADUbIiaP0
Sorry I can't embed for some reason...
Old 03-08-2017, 03:51 AM   #8
WillH's Avatar
I'll find the torque value for the manifold bolts and give them a check on Friday. I would assume that if they were that loose to allow movement that it would throw a code...
Old 03-08-2017, 08:09 AM   #9
Will, I would also check the engine and gearbox supports.
Old 03-08-2017, 03:53 PM   #10
WillH's Avatar
So does yours react the same as my video? Can't figure out if this is trompe l'oeil or if there is an issue here. I'll take measurements at rest and under vacuum...
Friday or Saturday morning...
Old 03-08-2017, 04:34 PM   #11
Ben-Auto-Design
Ben006's Avatar
It's normal.
At idle you're at 26inHg of vaccum inside the manifold, and when you open the throttle, you have almost atmospheric pressure.
This difference of pressure added with the design of the manifold (distance between manifold mounting flange and plenum) makes the whole thing move.
That's why the guys that went with forced induction have to strap the manifolds together
And also why Porsche is using a plenum with spin-locks and tie bar on all the last generation 911 with turbos!
IMGP3367.jpg Photo by caseyparkin | Photobucket
Porsche Tech in France.
www.benautodesign.fr
1982 928 S Euro
Ben006 is offline   Reply With Quote
Old 03-08-2017, 04:55 PM   #12
WillH's Avatar
Originally Posted by Ben006 View Post
It's normal.
Many thanks Ben
