Originally Posted by Gilles
Will is saying that the intake manifolds are moving away from each other ?, this means that one of them could be loose, but if you have a worn engine/tranny mount both manifolds will move along with the throttle body (and engine..)
Right, moving away from each other under throttle. So as he presses the throttle manifold vacuum level goes down, and the manifolds move apart.
