Old 03-02-2017, 04:08 PM   #1
Gas Cap locking issues
I reviewed postings and did not find anything quite like this, so help please.
When you actuate the lock with the key, the rod does not move into place. If you pull it out by hand it will retract and unlock.
I bought the new part and have had zero success.
Right now the fender well is open and with the mechanism hanging in the loom, the failure is exactly the same.
The rod will not extend out during the locking process.
Single beep response from the car.
If I am not being clear please ask as I sure need some insights.
David
Luckyman01 is offline   Reply With Quote
Old 03-02-2017, 07:45 PM   #2
Pdwight's Avatar
Good luck with this
My 2001 S fuel flap has never locked.
Dwight
Old 03-03-2017, 06:05 AM   #3
Dwight
It should be.
Old 03-03-2017, 11:47 AM   #4
kk2002s's Avatar
Mine never worked either. I replaced the locking mechanism and it still never worked. Never got any single locking beep
I was thinking that there is a programming issue. Debugging the electrical aspect is a daunting task as there is much to remove to get back to it. I have thought of putting some electricity to the old unit to see if it works.
Any starting point to testing the circuit would be helpful.
Seal Grey
Old 03-03-2017, 01:39 PM   #5
Mine needs Viagra as well. It wants to lock, but it just doesn't extend far enough. I figure I'll never park it in a neighborhood where stealing gas might occur.
tommydorsey is offline   Reply With Quote
Old 03-08-2017, 08:07 AM   #6
Gas cap lock update
Update, I replaced the locking mechanism to no avail, new one exhibited same failure. To review, will not lock, however if you manually extend the pin it will unlock.
With two straight pins and some wire I did a bench test. By putting power to one pin and then the other I was able to have it extend and retract.
Left to believe that the computer is braindead.
Any thoughts?
Old 03-08-2017, 08:16 AM   #7
Porsche "Purist"
Paul's Avatar
Has it ever worked or is this a recent failure? If never, I wonder if the new car turnover coding has anything to do with this....
1987 924S. 2002 996TT. PST-2
Old 03-08-2017, 09:05 AM   #8
kk2002s's Avatar
Originally Posted by Paul View Post
... If never, I wonder if the new car turnover coding has anything to do with this....
What does this mean???
I haven't tried pulling the pin out and then unlock yet to see if the pin retracts.
Seal Grey
Old 03-08-2017, 11:12 AM   #9
p3230's Avatar
I know that with the durametric pro on one of the module there is a place that will lock the doors the trunks and the gas door turn on the lights I tried it on mine but it did not work either. I'm taking mine to the dealer next month to get it reprogrammed as apparently when I had my module repaired it went in transit mode and they reprogram it to handover mode with the PIWIS to get all electrical working again.
Frank
p3230 is offline   Reply With Quote
Old 03-14-2017, 07:15 AM   #10
I am coming to the unhappy conclusion that I need to take her to Sunset in Portland Oregon. Expecting to be told that the security box under the seat is toast. Preparing myself for an "ouch".
It did work at one time.
Old 03-14-2017, 07:27 AM   #11
Multi-Boxer Driver
Deserion's Avatar
I found that when locking with the door key (versus remote), the lock pin doesn't engage consistently. It seemed to work when the door locks were cycled a few times when the car was running, though.
But back on keyless, works consistently.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
