Old 02-27-2017, 12:05 PM   #1
o2 sensor
whats the deal on o2 sensors, their prices vary considerably.
are the cheap ones as good as the expensive ones?
and which one is #1 bank1
madmac is offline   Reply With Quote
Old 02-27-2017, 01:38 PM   #2
The deal is if you know which ones you're looking for by part number you can find universal Bosch ones on EBay for a reasonable price. My car was throwing codes cause of fuel trim issues and I found a pair for $45. Only caveat was having to cut old connectors and splicing to new sensors. Very easy. No more codes and passed smog. Bank1 driver side US models
I stand corrected Bank1 Pass side, re:911Monty
Lapister is offline   Reply With Quote
Old 02-27-2017, 05:42 PM   #3
911monty's Avatar
This is incorrect in any country. Bank #1 is passenger side and bank #2 is driver side. Cylinders 1,2 & 3 are on bank #1. Cylinder 1 is on the right front of the engine.
Old 02-27-2017, 06:46 PM   #4
I had good luck purchasing OEM Bosch sensors, with connector off Amazing. Best pricing I could find with shipping.
Old 02-27-2017, 08:14 PM   #5
Topless's Avatar
Often "O2 sensor" fault codes are simply reporting a mixture problem upstream and the sensors are fine. Run your codes past the illuminati here first before swapping parts out.
Old 02-28-2017, 11:24 AM   #6
what side of the engine diagram here.
O2 sensor part numbers here.
Buy only ones with the wiring pigtails crimped on from the factory. Bosch makes em for Porsche. Porsche reboxes them and marks them up. I used the Bosch ones
Old 02-28-2017, 03:44 PM   #7
will a common bargin basement scanner give me those codes?
Old 02-28-2017, 03:53 PM   #8
Yes I've used a standard OBDII reader to pull codes, But the Durametric system is worth the investment over the long haul.
brybart is offline   Reply With Quote
Old 02-28-2017, 04:24 PM   #9
And O2 sensor codes are very specific.
Old 02-28-2017, 04:29 PM   #10
off to buy an obdII scanner.
thanks
