View Poll Results: IMSB Replacement Failure
Original IMSB working fine 39 55.71%
Original IMSB failed 1 1.43%
LN ceramic IMSB working fine 17 24.29%
LN ceramic IMSB failed 0 0%
Other IMSB replacement working fine 12 17.14%
Other IMSB replacement failed 1 1.43%
Voters: 70. You may not vote on this poll
Old 02-18-2017, 07:20 AM   #1
Fyeganeh's Avatar
Survey of failed IMS replacements
I know a lot of people have had their IMSB replaced, but how many of those replacements have failed?
Post your model, IMSB type, when replaced, how many miles on car now, how many miles since replaced, and whether it failed:
2000 Base, LN double row ceramic, 10/14, 65,500 miles on car now, 6500 miles since IMSB replaced, working fine
Fyeganeh is offline   Reply With Quote
Old 02-18-2017, 09:04 AM   #2
2002 S Tiptronic, 142000 miles when replaced 2012. 25k since replacement. Original IMSB had no signs of wear
2008 Boxster S PDE2
cas951 is offline   Reply With Quote
Old 02-18-2017, 09:52 AM   #3
Porsche9's Avatar
Have replace two the the LN ceramic bearing. Boxster S about 4 years ago and have put 30k on it since and the Carrera about 8 months ago and have put on 3k. Both had the seals fail and the grease wash out.
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
Old 02-18-2017, 10:07 AM   #4
jsceash's Avatar
31,000 on a rebuild with a new LN ceramic kit. About 40-50% of mile on track. However there were many improvements made and a lot of weight dropped inside the engine while rebuilding.
Old 02-18-2017, 10:11 AM   #5
986s had L&N ceramic for 20k miles then changed to final solution for past 10k. 996 has had L&N bearing for 25k. No problems with any of them. Neither of the originals had failed.
2000 Black 996 Aero, 2001 Forest Green Boxster S, 94 Midnight Blue 968 Cab, 1980 Pongee Beige 911SC Weissach Edition, 2004 BMW R1200CLC
ymkmkrz is offline   Reply With Quote
Old 02-18-2017, 10:47 AM   #6
ksjohn's Avatar
99 986. My original double row was failing. Seals leaked, bearing grease gone, oil in IM shaft. Bearing was still intact, but balls had worn down making bearing very loose.
Replaced with Vertex IMS bearing including oil pump modification. Also added non-bypass filter and filter mag. 17K on it as of now.
I replace my oil filter every 3K and check it for debris. So far, so good.
ksjohn is offline   Reply With Quote
Old 02-18-2017, 12:24 PM   #7
2000 S dual bearing, replaced with LN Retrofit as precautionary action. Original was in good shape at 50k. Sleep better. 😴
Old 02-18-2017, 01:05 PM   #8
I have never seen a sealed LN ceramic bearing, or one with grease in it.....
Old 02-18-2017, 01:32 PM   #9
Need For Speed
KRAM36's Avatar
Knock on wood, 2003 S with 122k miles on the original bearing. Looked at getting "The IMS Solution" put on it, but the cost was over $4k. No way I'm putting that kind of money in an engine with 122k miles on it.
2003 Boxster S
Old 02-18-2017, 02:54 PM   #10
Steve Tinker's Avatar
2001 986 S, dual row bearing.
Replaced mid 2010 with LN dual row ceramic @ 71,000km (44,000 miles) currently @ 110,000km (69,000 miles).
The original bearing had no visual wear, but unusually had only one seal fitted from the factory!!
My problem now is that the ceramic bearing has been in service for nearly 7 years and LN recommend replacing the bearing every 75,000 miles or 6 years - does this mean I'm on borrowed time.....
2001 MV Agusta F4.
Old 02-18-2017, 03:39 PM   #11
jaykay's Avatar
I am in the same boat exactly with time and mileage let me know what you find out..
986 00S
Old 02-18-2017, 04:58 PM   #12
Giller's Avatar
No more so than with the original bearing...
Old 02-18-2017, 05:36 PM   #13
Porsche9's Avatar
I'm referring to the original bearings.
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
Old 02-18-2017, 09:01 PM   #14
BirdDog's Avatar
2001 S - had IMS Solution (permanent fix) installed when engine was rebuilt 10K miles ago.
Working fine. Original single row IMSB had not yet failed at time of replacement but did show signs of wear. Also all grease had been washed out of the bearing.
Old 02-19-2017, 03:53 AM   #15
Master Brewer
Bootlegger's Avatar
IMSB replaced with 32K a year and half ago with LN ceramic. Piece of mind and smart move. Original bearing was greaseless and had slight wear.
____________________________________
2004 Boxster S Anniversary 550 Spyder
2018 Porsche Macan (wife's ride)
2004 Ford F-150 4X4 Crew
6 Fast Bicycles
Bootlegger is offline   Reply With Quote
Old 02-19-2017, 05:25 AM   #16
thom4782's Avatar
IMSB replaced at 120K with IMS Solution. Original single row greaseless but otherwise OK.
Old 02-19-2017, 05:31 AM   #17
geraintthomas's Avatar
2003 Boxster S, original IMSB, 96,000 miles, my daily car, no signs of failure, and no plans on changing it.
Ever.
Porsche Boxster S Type 986
Old 02-19-2017, 08:16 AM   #18
Can you edit and add one more item to the Poll? I'd be curious to know how many IMS bearings replaced that had wear.
2008 Boxster S PDE2
Old 02-19-2017, 10:34 AM   #19
If you have a survey, it should be divided into three surveys as the characteristics of the three generations of bearings is quite different. And since LN has 3 ball bearing SKUs...single, double and Single Pro.
As for some background on loose or looks/felt fine original bearings that were removed, do a search using the forum search function for IMS and JFP as he runs a shop and has done a whole bunch.
Old 02-19-2017, 11:02 AM   #20
Nine8Six's Avatar
JFP returns "Jackson Free Press" in Google. I'm not joking... LOL
.... and IMS returns pretty much all the same thing; some Gore-Gallery stuff nobody wants to see. Btw my bearing is in the 1st survey category, of course (cough's)
