Old 02-17-2017, 06:27 AM   #21
Wow, it's almost half the engine width.
Integrated right in the block.
I don't know exactly where or when I read it,
but the Boxster motor seemed real oil-intensive.
Like it was oiled differently, and alot more.
Something like 9 quarts, which is about
twice as much as most 3 liters.
Boxx is offline   Reply With Quote
Old 02-17-2017, 06:40 AM   #22
Porsche "Purist"
Paul's Avatar
Check this out:
3rd assembly page - Page 3
1987 924S. 2002 996TT. PST-2
Old 02-17-2017, 07:00 AM   #23
still plays with cars...
BoxsterSteve's Avatar
Originally Posted by Boxx View Post
Boring is usually something you do when you go to a bigger block.
And the 7.5mm bore increase seems like alot of aluminum to cut away.
I thought that was roughly how thick cylinder walls were in total.
Cutting half the cylinder wall away seems like bad mojo.
-- A 7.5mm bore increase seems like a different block.
On the other hand if an "S" has a bigger block, I would think
it would be more than 80 lbs heavier, especially considering
all the other heavier pieces like rotors and pistons adding weight.
80 lbs heavier total car doesn't seem like a heavier block.
Also, Paul said they were all the same exterior dimension.
-- Same dimensions and not much heavier seems like same block.
So which is it afficianodos?
- Is the "S" a different block, larger and heavier than the Base?
- Or does the "S" block have thinner cylinder walls than the Base.
It's got to be one of those two with a bore change.
You're getting hung up in old-school bore concepts.
The cylinder bores on these engines are varied size sleeves that are cast into the block when it's formed. The factory just substitutes different liners for different engine displacements.
Six speed 2000 Boxster S
Old 02-17-2017, 07:19 AM   #24
Porsche "Purist"
Paul's Avatar
He was getting there....
Old 02-17-2017, 07:43 AM   #25
Wow, that is really good. I'm about 2/3 thru and I'm saving the rest for later.
I don't really get the crankshaft 'stroking process' that takes it from 2.5 to 2.9
by going from 72 to 78.4 on assembly page 1 (especially when going from 72 to 78
gets you from 2.5 to 2.7)? You don't just adjust a crankshaft, like with a screwdriver.
I'm going to guess that the 'stroking process' is a euphemism for 'buy and install
a new crankshaft'.
Old 02-17-2017, 07:51 AM   #26
For MY 2004 the weights were:
Base manual 2811 lbs
S manual 2910 lbs
1941 Dodge Luxury Liner Coupe
Old 02-17-2017, 08:13 AM   #27
BYprodriver's Avatar
Originally Posted by Paul View Post
Maybe this will help...
This Really helps!
Old 02-17-2017, 08:14 AM   #28
I don't really think I am getting hung up on concepts.
I assumed a liner when I got that the engine was aluminum.
The XK Jaguars of roughly the same timeframe used 'Nicasil' liners.
Nickel is a real hard metal.
(They had problems with this alloy but I can't remember exactly what.
Something to do with leaded gas maybe.)
Liners are fairly thin. You don't just shave 4mm off of a liner (8mm bore increase).
You don't start out with a 10mm thick liner. At least I don't think.
What you do is increase the aluminum cylinder size (bore)
and put a similar-thickness liner inside of that.
If you had a liner. But - that is not how Porsche does it.
They have some coating placed on the inside cylinder walls.
I forget the name, but it acts just like a liner.
I distinctly remember reading that is why you can't just rebore
a cylinder in a Boxster.
Cylinder liners are not for changing bore sizes.
And in a Boxster they are not for changing period.
Unless you can show me how, my question stands:
- Bigger block or thinner walls?
(And keep in mind, that is even if the Boxster had cylinder liners instead of cylinder lining.)
Old 02-17-2017, 08:31 AM   #29
I'm not an engine expert, but it seems to me you could maintain the same cylinder wall thickness and block dimensions at the expense of smaller (narrower) cooling jackets?
Someone can probably correct me on this.
Old 02-17-2017, 08:42 AM   #30
Acceleration also depends on the gear ratios being used and the 5 speed and 6 speed are quite different. Maybe a question to ask is how many gear changes do you need to get to speed x?
Old 02-17-2017, 08:43 AM   #31
Maybe, but that would be a different block.
And if it was a different block, they probably wouldn't choose
to narrow the cooling jackets to increase bore size.
Old 02-17-2017, 09:24 AM   #32
Porsche "Purist"
Paul's Avatar
From wikipedia:
All 986 and 987 Boxsters use the M96, a water-cooled, horizontally opposed ("flat"), six-cylinder engine. It was Porsche's first water-cooled non-front engine. In the Boxster, it is placed mid-engine, while in the 911, rear-engine. The flat, mid-engine layout provides a low center of gravity, near-perfect weight distribution, and neutral handling. The engines had a number of failures, resulting in cracked or slipped cylinder liners, which were resolved by a minor redesign and better control of the casting process in late 1999. A failure for these early engines was a spate of porous engine blocks, as the manufacturer had difficulty in the casting process. In addition to causing problems with coolant and oil systems mingling fluids, it also resulted in Porsche's decision to repair faulty engines by boring out the cast sleeves on the cylinders where defects were noted in production and inserting new sleeves rather than scrapping the engine block. Normally, the cylinder walls are cast at the same time as the rest of the engine, this being the reason for adopting the casting technolog
Old 02-17-2017, 09:29 AM   #33
Rennzenn
j.fro's Avatar
Here's a little chart I've put together regarding M96/M97 engines. They all have a very similar block, except for the 996 GT3:
Be careful comparing factory weight specs. Options can throw things off. Just a guess, but I'd bet that a fully loaded base 00-04 986 manual would weigh about the same as a really low option manual S model.
FWIW, somewhere I read that the 6sp is about 100 lbs heavier than the 5sp.
I don't know the weight of the tiptronic, but it wouldn't surprise me if it weighed the same or more than the 6sp.
Rennzenn
Jfro@rennzenn.com
j.fro is online now   Reply With Quote
Old 02-17-2017, 01:03 PM   #34
Porsche "Purist"
Paul's Avatar
The 996 GT-3 and 996 Turbo do not have M96/97 motors.
Old 02-17-2017, 01:04 PM   #35
Porsche "Purist"
Paul's Avatar
This Really helps!
Thanks that really shows the casting differences.
Old 02-17-2017, 01:23 PM   #36
JayG's Avatar
03/04 S are 258 HP not 250
Old 02-17-2017, 02:37 PM   #37
Muskoka Minute's Avatar
I can't speak to a base model being more or less nimble, but I have driven mine rather aggressively on some very twisty two lane roads, piling into curves at twice the posted limit and I can safely say it's the most tossable car I've driven. It has way more grip than I have cojones.
And where were you driving this fast Steve?
Not in Muskoka I hope. lol!
Cheers!
My Beast 2004 Boxster SE #0174
- 3.8 with all the internal goodies, Under-mount Pulley, IPD Plenum, 996 Intake, Softronic Tune, 987 Factory Sport Exhaust, skid plates, IMS solution, Ohlins R&T, RSS Toe Links, Camber Plates, Michelin Pilot Super Sport on all 4 corners, Alpine Double Din c/w new speakers & amps.
Muskoka Minute is offline   Reply With Quote
Old 02-17-2017, 05:04 PM   #38
I plead the 5th....
Old 02-17-2017, 06:17 PM   #39
I owned a '99 and a '01S. 201 and 250 HP. I never found much difference though I was not racing. The '99 was a bit more to my liking because you could put your foot down harder/longer without attracting government attention. Same tires were on both. Good tires and an alignment to match the type of driving you want to do make a world of difference. Likewise a freshened suspension, the right brake pads...
Old 02-17-2017, 07:33 PM   #40
Porsche "Purist"
Paul's Avatar
The 2.7 is a nice motor, it revs freely, sounds great, and has sufficient power. But then I have almost as much fun in my 924S as in any of my other Porsches.
