02-08-2017, 08:59 AM
Engine bay cleaning
Before the spring is in full effect I would like to clean my 986 motor/engine bay. I did a ok job when I bought the car a year ago. I have invested a small fortune according to my wife on the car as to be expected when buying a 16 year old Porsche. I would like to clean the old grease,oil, dirt, etc. from under the engine and topside. My plan is to mask off the cabin with plastic sheeting and use a engine specific cleaner. I have done this on my previous cars but this time I want a really good cleaning. I also will raise the rear of the car on ramps to clean under the motor. I will not use high pressure water but more of a fine mist from my hose. I usually use Meguiars/Griots products but does anyone have any tips before I buy any products or attempt the detail? I will use an engine detail spray to freshen up the plastics nothing that leaves a greasy residue.
02-08-2017, 09:18 AM
Multi-Boxer Driver
My method:
Sprayer 1 - full-strength Simple Green
Sprayer 2 - tap water
Mist on, and then mist off (repeatedly) until clean.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
02-08-2017, 09:28 AM
Be careful, you may inadvertently do much more harm than good.Water + low voltage electrical=problems.
It is cleanliness inside the engine that matters.
We could give you n alternative to-do list if you want :-) ?
02-08-2017, 09:34 AM
Administrator
I use Adam's In & Out Spray and a rag. I couldn't believe something as simple as this spray and a rag would do much until I tried it out. Now it's the only way I clean my engine bay. You can use it on every surface in your bay. You also avoid using any water in the engine bay that may cause problems.
In & Out Spray - 9oz - PelicanParts.com
02-08-2017, 10:18 AM
I use spray 9 ( citrus cleaner ) and a paintbrush to loosen everything up then gently rinse with water. I go over it with 303 protectant.
02-08-2017, 10:19 AM
02-08-2017, 04:37 PM
If your UOA matches the outside - great !
02-08-2017, 09:40 PM
So it looks like a 50/50 mix between rinsing with and without water. I have cleaned engines before and obviously your using a fine mist to rinse. Our engines are exposed to the elements for the most part so I can't see why a fine mist of water would harm anything. Its not like I will use a full jet of high pressure water on the alternator. What product do most use?
02-08-2017, 09:45 PM
Ha my to do list IS getting done- IMS, RMS, Clutch/flywheel, water pump/t'stat, belt, front motor mount, air filters, spark plugs/tubes, brake fluid, coolant flush, convertible top replaced, new tires/rims, alignment, fuel filter, 997 shifter=done, and AOS when it dies as well as coolant tank if it dies.
02-09-2017, 08:48 AM
98 Arctic silver 986
Ha that looks exactly like my already done list.
02-09-2017, 08:56 AM
Because of the unusual location of the M96 and all the shielding underneath ,the many electrical connections on the top of the engine are very protected from the elements.But those electrical connections are buried under the inlet manifolds. Checking them all if the engine misbehaves after washing could take days.As we say in the biz - bring it on -it is a "Time & Cost " job so it is blank check time.
If you care to Google "washed engine problem" you may understand.
On an M96 the OCD cleanliness issue is UOA not outside shine.
02-09-2017, 09:21 AM
most of the grime is at the undercarriage which is where I will concentrate on. As far as the top of the engine near the intake manifold I will probably concentrate around the out edges not directly of the top as I cleaned that area as much as I could by hand.
02-09-2017, 09:35 AM
Good. That will help you track down oil leaks. Most are just a nuisance but some are good to catch early- like RMS or spark plug tubes or cam covers.
02-10-2017, 05:10 AM
Project Addicted
I use a small home steam cleaner and simple green. A stiff paint brush to loosen up anything that doesn't want to move and then blast it off with the steamer. The steamer gives control where a water spray does not. Makes the dirt disappear!
______
Jon
1966 912, 1976 911
1986 944, 2000 Boxster
05-03-2017, 07:30 PM
So the last time I cleaned the engine bay was may 2015
Changed my air filter today and here is how it looked
I simply wiped it down with a cloth and a bit of quick detailer
05-04-2017, 05:05 AM
Its an ugly engine and its buried in the car. Aside from cleaning up after a major oil leak, whats really the point? Best I did was wipe with a damp microfiber
05-04-2017, 05:43 AM
Your wife will be SO happy
(I had the same reaction over purchasing!)
2001 Boxster S, Guards Red
05-04-2017, 09:43 PM
A clean engine bay is easier to find leaks and other issues plus my OCD wants a "clean" engine bay.
2001 Boxster 986 S, 6spd, arctic silver, black interior with black rear glass top, 18" staggered black powder-coated Porsche twists, aftermarket exhaust, smoked headlights and taillights, 20mm rear hubcentric billet wheel spacers, 5mm front billet wheel spacers, de-snorkled, passenger airbag switch, 997 shifter upgrade, LN engineering dual row update, Koni FSD with H&R sport springs, Joe Toth composites rear duck tail spoiler.
05-05-2017, 05:32 AM
I also wash my engines. Always use simple green or any of the citrus based cleaners, a nylon brush and a rag. Never pressure wash as I don't let them build up to the point of needing that and just don't want to get water into something that it doesn't need to get into.
One thing that I hate is when people use armor all or any of the other shiny treatments afterward. All they do is give a sticky surface for dust and grime to accumulate. They make the car look like it was on a used car lot IMHO.
05-05-2017, 09:52 AM
I used aerospace protectant, it seems to have repelled most of the dust for the last two years.
