Old 02-09-2017, 07:56 AM   #11
Gelbster
Originally Posted by marcoc View Post
So it looks like a 50/50 mix between rinsing with and without water. I have cleaned engines before and obviously your using a fine mist to rinse. Our engines are exposed to the elements for the most part so I can't see why a fine mist of water would harm anything. Its not like I will use a full jet of high pressure water on the alternator. What product do most use?
Because of the unusual location of the M96 and all the shielding underneath ,the many electrical connections on the top of the engine are very protected from the elements.But those electrical connections are buried under the inlet manifolds. Checking them all if the engine misbehaves after washing could take days.As we say in the biz - bring it on -it is a "Time & Cost " job so it is blank check time.
If you care to Google "washed engine problem" you may understand.
On an M96 the OCD cleanliness issue is UOA not outside shine.
