Old 02-08-2017, 08:24 AM   #1
H&R street coilovers
Hello all,
Does anyone run these for street use and the occasional DE? My 106k mile car suspension is basically toast, so I'd like to upgrade a bit, but don't want a too harsh a ride for the street.
Anything else required with a moderate lowering of say an inch or so? No issues with camber at that ride height, correct?
Old 02-08-2017, 12:08 PM   #2
Originally Posted by Quadcammer View Post
Hello all,
Lowering your car 1" may require an adjustable link for the rear toe (mine did..) and ended buying Rennline set.
Old 02-08-2017, 07:50 PM   #3
Gilles, were you able to keep the stock sway bar drop links with a 1" lower ride height? I was thinking that adjustable drop links may also be needed??
Old 02-08-2017, 08:26 PM   #4
On the slippery slope
JayG's Avatar
I lowered my car around 20 mm using the M030 ROW springs and have the stock droplinks
2004 996 Targa Tip
Instructor - San Diego region
Old 02-09-2017, 04:31 PM   #5
Hello Tom,
Actually I used the OEM drop links for almost 8 years without any issues,
Yessterday I finally was able to reinstall the front suspension, as the coilovers arrived from KW (being rebuild) and I installed the Tarrett links as well, tonight I will preload the suspension to torque the LCA's, control arms, links etc,.
Hopefully my back will allow me to start on the rear suspension as well.. LOL
