02-21-2017, 07:45 PM
#121
This has to be one of the coolest threads I have ever seen - So very very interesting in so many ways.
02-22-2017, 09:50 AM
#122
Originally Posted by rs10
Sounds like you have some amazing tools at your disposal! Not that I can follow every detail of course, and I’m particularly puzzled about one thing.
I understand you are doing virtual aero modeling/testing using computational fluid dynamics. But you also mentioned putting a pressure plate/sensor under each wheel. You also have access to a windtunnel? Or … ?
Also, the 15 degree test at 160kmph you mentioned sounds like driving 160 with a 40+ kmph sidewind. That’s rather quick, so no wonder you got a left/right bounce! But I wouldn’t worry about experiencing anything like that when cornering at 160, as what is happening in the air should be quite differernt, no? For instance, suppose that on a 160 kmph corner you cross a line on the track perpendicular to your direction of travel. If your car is cornering neutrally, then the air that passes exactly over the center of your car when the front wheels cross the line will also pass exactly over the center of your car when the rear wheels cross it (Well, ignoring how the air might get pushed to the side forwards by the car). That’s quite different from a side wind. (And also rather different from going straight. As the front and rear of the car pass the same line, they will be further to the outside. And as the middle passes it, it will be further to the inside.)
Also, even if what happens in the air were the same as with a side wind, 15 degrees is quite a lot. Suppose it was exactly like a side wind (with I can only imagine happening if you have four wheel steering such that the car stays pointing in the same direction, but it moves 15 degrees to the right or left). The wheels would have to be turned at least 15 degrees for that to happen, so your steering wheel would have to be turned, I don’t know, 240+ degrees? I would definitely worry about that at 160!
Admire your knowledge; Clearly there are two kind of people. Some that are clueless and need CFD tools to aquire understanding and knowledge, and some cool others who can compute nearly all of this stuff out of the head. Fascinating thread indeed!
No 'physical' wind tunnel here, you asked.
That virtual wind tunnel/CFD data (results) was exported into spreadsheets then called back into a totally separate structural analisys. That cfd data can be re-used for e.g. excitations or forced displacements if you prefer. Post structural analisys is meant at solving mostly displacement, force and strains/stress problems on the car componets.
So... set evironment; gravity, humidity, temp, and you can predict the behaviour of lets say; your suspension's preload/compression, damping, the force generated on any brackets, your mirrors' mouting points... stuff like that. You can also predict response dynamics (modal) such as vibrations onto body panels (accoustics) and some other more adv nonlinear problems eg. elasticity, buckling, laminates/ply; how much is my 5mm thick cheap fiberglass front bumper is bending at 200miles an hour (seriously lol).
All started from a 180km/hrs beaten up air fluid data mapped node-by-nodes onto a Boxster car! My training folder is now at 30+ gigabytes of raw *.dat text files bud
Learning the fun way! Chk back in two years... I'll be the official 986Forum Formula 1 Team Aerodymics - adviser
02-22-2017, 10:48 AM
#123
Originally Posted by jb92563
Glider pilot, so I'm very familiar with spoilers and how they effect lift on wings.
Jb92563
If you are a licensed pilot, would you consider taking me for a ride on a rented G-102/103 at Warner Springs?
I live in OC and could do a nice drive down Highway 79 and perhaps having lunch afterwards at Ramona?
Regards, Gilles
PS: Sorry for hacking this great tread, just could not resist
02-22-2017, 11:55 AM
#124
Originally Posted by Gilles
Jb92563
Regards, Gilles
I'll go for a glider ride as well
03-01-2017, 01:46 PM
#125
Originally Posted by Nine8Six
You are welcome for those 'genreric' air flow visuals! I plan on doing the 996 but will post using my RL account under the same alias. I'll shoot you a PM to let you know where to find those. As for messing-up with aero; I think it is fair to say that Porsche have carried out this work and have designed the car to safety limits already  Any modification can be costly if not validated indeed. So best to stick to what the pro (Porsche) recommends loll
If you’re also planning on doing something 997 related, well, I’ve done my homework on the Sport Classic and I have a suggestion for you.
The Sport Classic is the only 996 or 997 with a duck tail – on other cars it wasn’t even an option. As far as I can tell, the closest equivalents to the 997.2 Sport Classic are the 997.2 C4 GTS and the 997.2 C4S with the X51 powerkit. All three are wide bodies, and will have larger air intakes in the front bumper than normal Carreras. (The next closest match is the 997.2 C4S without the powerkit, though not sure if the bumper, radiators, etc. are the same.)
The C4 GTS has a Cd of 0.30, versus the Sport Classic’s 0.32. It’s easy to blame the duck tail, but it could also be the double bubble roof or the aftermarket looking side skirts. And I’m not sure the bumper is the same either. It would be very interesting to see what your software shows about both drag (where the difference is) and lift.
By the way, the GTS was available with and without a GT3 style wing (which was probably an option on C4Ss as well). Comparing eiher version to the Sport Classic would be hugely interesting. And if you will be modelling enough cars to do all three rear ends (normal, duck tailed, and winged), then you’d have all the rear aero answers!
Anyway, much though I’d love to see the aero analysis of my car, as you’ve probably guessed, I’d give my vote to the Sport Classic. And I’m betting I’m not the only 996 (or 997) owner who would do the same.
04-15-2017, 03:51 AM
#126
I guess I´m not the only one who isn´t too pleased with the visuals of the original wing. From a visual standpoint I think this one is the best I´ve seen (my personal preference): http://pictures.topspeed.com/IMG/crop/201012/first-generation-por-4_1600x0w.jpg
Even if I still would like to modify it, I think it has the right thing going for it. Anyway, since I´d except the Porsche guys to have made their homework I´d hesitate to make any changes without some fluid-dynamic calculations to back it up. Great to see this initiative from Nine8Six, I´m hoping for some more conclusions regarding the rear wing vs aftermarket stuff.. My dream product would actually be a carbon fibre rear hatch with included (good looking) wing with a mechanical raise-function like the one on the Turbo.. Unfortunately I don´t think I have the ability to produce it myself, at least not the time..
Again all credits to Nine8Six, lifting the forum to another level
05-08-2017, 05:08 AM
#127
This thread is awesome! Would it be possible to make those drawings with "humps" on?
interested to see if they provide any aerodynamics changes.
08-06-2024, 11:35 AM
#128
Roof Mounted wing - CFD best guess?
This is a Very old thread, but had some people participating who know aerodynamics and that is what I need!
for a 24hr of Lemons race car... 2002 base boxster with the convertible top removed... would mounting a wing to the cage on top of the cockpit be a "thing" that works?
Lemons is whacky, we do whacky stuff... lots of people mount things on the roof... I'm wondering if I can do something that is functional. Any actual downforce would get distributed through the cage and it's 6 mounting points to the floor... so it wouldn't just be bending/flexing a roof panel.
it would mount to the cage and then I have a roof panel that is super thin sandwich aluminum that just slides over the cage.
Isn't the air coming up the windshield the fastest air around the car? so basically it would be a 'blown wing' circa Renault F1 a decade ago.
or am I the idiot?
08-06-2024, 02:06 PM
#129
or am I the idiot?
I am curious to find any educated comments as well, because all of the Spec. Boxters use a hardtop but not sure if it's per regulations or because you have better airflow with the hardtop.
08-06-2024, 04:03 PM
#130
They also don't run a wing, and spec is spec.... They definitely can't show up with a wing sitting on the roof.
But I can do whatever.
No idea if this is a genius idea or nonsense concept.
