Old 01-24-2017, 04:31 AM   #1
07 Carrera S Cab
Boxtaboy's Avatar
You sure you have the right size belt? It was easy for me to route the new belt on when changing it.
Old 01-24-2017, 04:44 AM   #2
jeeper31's Avatar
My friend gave me the belt and the packaging is right. As long as the belt was in the right package it should be fine.
jeeper31 is offline   Reply With Quote
Old 01-24-2017, 06:33 AM   #3
07 Carrera S Cab
Boxtaboy's Avatar
Ok, if you say so. To be sure, you might want to take the old belt, and compare it to the new one to see if it is the same, or try to put back on the old one, and see if it is that hard to put on. Should be easy to figure out that way if the new belt is correct size.
