Old 01-18-2017, 07:58 AM   #1
batshapedheart's Avatar
Radio Receiver Defective
For about a year my key fob hasn't been working and I've been opening and closing using the key. Last week ChrisBlueZenith and I hooked up the Durametric and under Alarm we got:
54
Status: Not present
Ocurrance Counter: 17
So, where is the radio receiver and how do I change it? And more importantly, will this get my key fob to work?
2002 Boxster 2.7
batshapedheart is offline   Reply With Quote
Old 01-18-2017, 10:13 AM   #2
Multi-Boxer Driver
Deserion's Avatar
Do you have an aftermarket stereo by any chance?
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 01-18-2017, 10:29 AM   #3
The alarm system ground wire on the radio chassis is disconnected.
Old 01-18-2017, 01:48 PM   #4
And if you need your radio code because the diplay says "CODE" when you reconnect the ground wire mentioned by JFP...
There is a code # look up service somewhere(by VIN). But where ,I do not recall. Anybody else?
In theory there may be a sticker under the hood but I have never seen one intact or legible.
Old 01-18-2017, 05:11 PM   #5
On both my cars the sticker was under the hood and legible! And there was another copy in the service manual. Some nice person had written the radio code in each place before my ownership.
The dealer can get the code for you if you provide the Vehicle Identification Number (VIN) and the serial number of the radio.
Post the serial number of the radio on renntech.org and there is a kind gent who can get you the code. There is a specific thread where you post the serial number and the gent gets back to you in a day or two with numbers to try based on an algorithm someone worked out.
How do I get the serial number?
For a Becker CDR220 (the most common Boxster radio, the one with a CD player inside the detachable front plate) you can turn the radio on with the power button, then press the TP button until Becker 1 appears on the LCD. Then use the right-hand knob to turn to the selection for "Seri:" which is followed by the serial number of the Becker CD unit.
The serial number is also on a sticker on the rear of the radio but you have to pull the radio to get at it. You need Radio pulling forks from Becker to do this. Any car radio shop or the dealer can do this for $$$. But why bother.
Old 01-18-2017, 06:58 PM   #6
Thank you for posting this Mike.
In case anyone needs it ,here is the help link:
https://www.renntech.org/forums/topic/18982-lost-radio-code-faq-read-this-first/
Old 01-19-2017, 07:21 AM   #7
Pioneer double DIN
Yes, I have an aftermarket radio. A pioneer double DIN ever since I got the car. The fob worked back then. Maybe I should check those wires.
2002 Boxster 2.7
