Old 01-19-2017, 01:11 PM   #1
mustang2porsche's Avatar
Well I got my hub carrier in the mail and the brake cable is still attached, I found a diagram online that says to remove a clip and the cable should come out, but I can't remove the clip; well at least without removing the brake shoes
mustang2porsche is offline   Reply With Quote
Old 01-25-2017, 09:00 AM   #2
So now, my whole axle came out of the transmission,the hub is still stuck to axle though.
Old 01-25-2017, 10:19 AM   #3
steved0x's Avatar
You can get a loaner tool 3 jaw puller from most auto parts stores and use it to push the axle put of the hub.
Old 01-25-2017, 11:23 AM   #4
My local porsche indy just drove 30 miles to get this axle off and replace my hubby now for only 150 bucks... kinda glad but now my diy ego has been shot, also I lost some gear oil due to my lack of care.
What also got me was I panicked when I noticed the diff cover came off.
Old 01-25-2017, 10:48 AM   #5
My experience is the pickle fork ALWAYS works when you hit it hard enough but it always rips up the ball joint boot. Before I did my last bearing I picked up the ball joint tool from Autozone for about $30. The cheap one I had wouldn't open wide enough for the main ball joints but the new one does.
I also am able to pull bearings with an improvised tool. A piece of pluming I had on hand (i think its a 4in to 3in stainless steel tubing adapter) , some extremely thick washers special ordered from McMaster Carr, and a 1 inch threaded rod. I've done bearings half a dozen times with it.
Wret is offline   Reply With Quote
Old 01-25-2017, 02:23 PM   #6
Boxster is fixed, and it's weird that is so quiet. Very quiet.
Sorry for the double post but hub carrier is changed, and I'm glad
Old 01-26-2017, 10:54 PM   #7
I am my own mechanic....
Timco's Avatar
You still went well beyond what many will try. Good job!
'08 VW Touareg T-3 wife's car
