Old 01-02-2017, 06:01 AM   #2
JoJo,
I don't believe it is that simple. If it is a hall effect sensor (which I suspect) you can't do meaningful static readings. If I get a chance I will look up in the repair manual for diagnostic tests. I have a nagging suspicion the best test is to replace it and see if the problem goes away.
1941 Dodge Luxury Liner Coupe
