Old 12-21-2016, 12:14 PM   #1
Vacuum or overflow hose?
While busy tracing possible vacuum leaks I came across this hose. This hose connects to the hydraulic reservoir, the other end is not connected to anything. Is this a vacuum hose or the overflow for hydraulic oil?
2001 Boxster S
Stratbox is offline   Reply With Quote
Old 12-21-2016, 12:23 PM   #2
No, it is not a vacuum line. It is the overflow for the power steering expansion tank.
Old 12-21-2016, 01:01 PM   #3
I replced mine with a longer one that directs any overflow to the ground. The stock hose is so short,any overflowing p/s fluid goes all over the engine. On my '01 S, it uses a 5.5mm hose IIRC
Old 12-21-2016, 01:11 PM   #4
Thanks I will extend the overflow hose too.
