12-02-2016, 03:03 PM
Please post your pictures of auxiliary center gauges!
Playing with the idea of adding in some VDO gauges into one of my center console cubbies, for oil temp / oil pressure / voltmeter.
Would like to see some pictures posted from those of you who may have preceded me with this thought, for inspiration purposes.
A "search" did not bring forth much.
Thanks - DM
2000 Ocean Blue Boxster S
1980 Ferrari 308 GTSi
2019 Alfa Romeo Giulia Ti Sport AWD
12-02-2016, 03:28 PM
There Is No Substitute.
This is the thread you are looking for.
Most of the ways I have seen it done are similar to these. Pedro sells a kit, which is the only prepackaged one for the 986 I know of.
EDIT:
Another one
12-03-2016, 06:33 AM
2003 S, Arctic Silver, M6
03-29-2017, 04:19 PM
Done!
I bought an old used CD holder and hacked it apart so to serve as the framework for the aluminum bezel. So now it slides right into the console like it was made for it.
The original VDO hot incandescent illumination bulbs were replaced with cool amber LED lamps, so to match the OEM gauge lights. Looks nifty in the dark.
Super pleased with the results.
03-29-2017, 05:44 PM
Here's mine:
What bulbs did you use, I didn't wire mine up because I didn't want the stock bulbs and also I never thought I would care if it was dark out and I couldn't see the gauges, but now it I bugging me. I too cut apart a cd holder to make the base
03-30-2017, 02:04 PM
Nothing fancy, just some low powered generic amber LED lamps.
Last time I was at my local branch of a well-known national auto parts chain, I noticed that they had a wide variety of these LED lamps hanging on the peg. Just pull one of the incandescent lamps from one of your gauges and match them up.
Thanks - DM
03-30-2017, 05:58 PM
I've always liked the combination of idiot lights to get your attention and gauges to keep you informed. Do any of these add-ons keep your idiot lights functional?
03-31-2017, 03:08 AM
As far as the oil pressure goes, you replace the OEM idiot light sending unit on the cylinder head with a VDO one which has outputs for both the light and the gauge.
So yes, you then have the best of both worlds.
Thanks - DM
03-31-2017, 03:27 AM
Very nice job
01-06-2024, 07:13 PM
Originally Posted by Dave80GTSi
Old thread, I know, but wondering where this shift boot came from as I've looking for a replacement and nothing at all has popped up anywhere.
Also, more in the line of this thread's original purpose, has anyone added an oil pressure gauge to the right of the gauge cluster where the 996 oil pressure gauge lives? Seems like there's enough real estate although a standard VDO gauge might be pushing it and I don't know how much depth there is. I'm sure something could be arranged, maybe a smaller gauge or a maybe a sideways reading gauge like the 996 gauge. I just don't want to mess with the 996 cluster due to price, compatibility, coding, etc.
00 986S
86 944 Turbo
87 VW Scirocco 16v
87 Alfa Romeo Milano
77 Alfa Romeo Alfetta Sedan
01-06-2024, 09:30 PM
99.9% sure that is an ICT shift and boot from eBay. I have spent an unhealthy amount of time looking at shift knob options.
I agree an oil pressure gauge would be nice.
2001 Boxster S | Triple Black | Stock 17s | Bilstein PSS9s | BAD Shifter | 6x40w Cabrio Amp | 986.2 muffler
"Sixty percent of the time, it works every time!"
01-07-2024, 05:29 AM
I added oil pressure gauges to 2 of my boxsters in the same location. The gauge can be seen with both three and four spoke steering wheels. The hardest part is running a wire under the console to connect to the sensor on the engine.
In one case I used a cheap VDO clone gauge and sender from Amazon. The pressure sender for the gauge can be installed on the bank 2 head, keeping the idiot light sender on the bank 1 head.
On the other car I used a VDO gauge and the sender from a 996 which has both idiot light and gauge senders. The gauge is visible with both three and 4 spoke steering wheels.
Another possibility is an LED gauge something like this. The photo is a (very) temporary temperature gauge I installed while working out a wiring problem after an engine swap, I would think a place could be found to install it properly.
Grant
01-07-2024, 07:29 AM
I think you are on the right track adding the additional gauges. On cold mornings it is nice to know that the oil is circulating optimally before you thrash the car. I understand that you are specifically looking to add auxiliary gauges, but there are other options. I took a different approach and added a 996-gauge cluster to my car.
https://986forum.com/forums/boxster-general-discussions/43017-carrera-gauge-swap.html
I enjoyed the project and because I started with a defective 996 cluster it wasn't expensive. Now when I look at a stock Boxster cluster, it looks like the factory left something off.
