Old 11-24-2016, 01:06 PM   #1
Distorted Screen
Hi.
Can anyone suggest how to get my climate control screen to clear up?
I caused this a few weeks ago when I was whipping down the interior. I did not squirt any cleaner in there, but the rag did have some on it. I also don't think I pressed too hard, but apparently I must have. Since the initial damage, the screen has cleared quite a bit, but this image here is pretty much how it's looked for over a week. So I'd say it's not getting much better now.
Any ideas on how I might get this to clear up?
Thanks!!
BoomerRoadie is offline   Reply With Quote
Old 11-25-2016, 04:13 PM   #2
still plays with cars...
BoxsterSteve's Avatar
Looks like you have a damaged climate control LCD.
One of these https://modulemaster.com/rebuilds/shop/comfort/lcd-repair-kits/porsche-lcd-kit/ will fix you right up.
Six speed 2000 Boxster S
Old 11-25-2016, 09:08 PM   #3
How on earth does that work? By the looks of the pictures it looks like you have to disassemble the entire climate controller, yet the write up indicates otherwise.
Thanks for the reply.
Old 11-25-2016, 09:33 PM   #4
Yes, you have to remove and disassemble the climate control unit to replace the screen. It's easy.
Old 11-26-2016, 08:10 AM   #5
On the slippery slope
JayG's Avatar
This one is an exact replacement with the same icons ads factory.
996/986 LCD Display unit wth connectors (replacement kit)
Its also less $$ than most
Many others have different icons
It is a very easy DIY. When I did mine with the 914 rubber kit, it took maybe 15 minutes tops including removing and reinstalling the climate control
Use the instructions you can download from Module Masters
http://modulemaster.com/rebuilds/instructions/climate-control/Porsche%20Climate%20Control%20LCD%20Rebuild%20Kit% 20Instruction%20Manual.pdf
2004 996 Targa Tip
Instructor - San Diego region
Old 05-26-2017, 06:25 AM   #6
Muskoka Minute's Avatar
This is the one I used and it was great.
An exact replacement for the original.
My Beast 2004 Boxster SE #0174
- 3.8 with all the internal goodies, Under-mount Pulley, IPD Plenum, 996 Intake, Softronic Tune, 987 Factory Sport Exhaust, skid plates, IMS solution, Ohlins R&T, RSS Toe Links, Camber Plates, Michelin Pilot Super Sport on all 4 corners, Alpine Double Din c/w new speakers & amps.
Muskoka Minute is offline   Reply With Quote
Old 05-26-2017, 09:16 PM   #7
Pdwight's Avatar
If you buy a used climate control module there's no guarantee it
will even work in your car, not all the same. I did this and the control unit was not compatable with my car. I would up exchanging the LCD screen only using the one I purchased as a donar
Old 11-26-2016, 09:39 AM   #8
07 Carrera S Cab
Boxtaboy's Avatar
I just bought a working used one (entire unit) on fleabay for $75 shipped as a spare if mine ever craps out.
Old 11-26-2016, 12:57 PM   #9
Boxy_02's Avatar
The kit is very easy to use as others have said.
2002 Porsche Boxster Carrara White - 103,000 miles
Boxy_02 is offline   Reply With Quote
Old 05-24-2017, 11:16 PM   #10
lowpue's Avatar
I just repaired using an new LCD kit for $60. Piece of cake, took about 20 minutes and works perfectly.
2020 Taycan Turbo S - DD Rain
2015 Huracan - DD Sun
2002 Boxster - Play Car
2000 C2 Aero - Track Car
1965 Dodge Coronet 440 - Nostalgia
lowpue is offline   Reply With Quote
Old 05-25-2017, 09:10 AM   #11
The LCD repair kits are easy to install as long as you take your time and are detailed.
I did mine last Summer--well worth the effort.
'02 Boxster S
'16 GTI PP
'17 Bolt (with a B)
Nmbrsix is offline   Reply With Quote
Old 05-25-2017, 09:46 AM   #12
If you buy a used climate control module there's no guarantee it won't do the same thing to you down the road. Best to get the repair kit. I got it and took mine apart with instructions provided and it was no big deal.
