Old 11-09-2016, 01:59 PM   #1
Question Oil filters for the Screw on adapter
I'm wondering what / which oil filters can be used with the LN screw on adapter
any one using this system , what filters are recommended
mfm22 is offline   Reply With Quote
Old 11-09-2016, 02:12 PM   #2
"50 Years of 550 Spyder"
10/10ths's Avatar
I have one...
Oil filters to use: Napa Gold 1348, Wix 51348, K&N HP-1002
Old 11-09-2016, 02:16 PM   #3
1999 base
Meir's Avatar
based on recommendation i got from another forum member, im using WIX 51042
Old 11-09-2016, 03:41 PM   #4
steved0x's Avatar
If you have the IMS solution adapter you use a different filter, the regular non ims solution adapter uses Wix 51042 or equivalent.
Old 11-09-2016, 05:00 PM   #5
Thanks , surprised no Mobil 1
Old 11-09-2016, 06:44 PM   #6
+1 on the Wix 51042
Old 11-09-2016, 08:49 PM   #7
thom4782's Avatar
Just to be clear:
IMS Solution uses WIX 51348
Spin on oil filter adapter uses WIX 51042.
Is this correct?
Old 11-10-2016, 12:08 AM   #8
still plays with cars...
BoxsterSteve's Avatar
Yes. That's it.
Six speed 2000 Boxster S
Old 11-10-2016, 05:26 AM   #9
Luckyed
Luckyed's Avatar
I want to start to do all of my own oil changes and would like to use a spin on adapter.
Would it be safe to say that I can tell if my car already has a spin on adapter on it by seeing if the oil filter housing is attracted to a magnet?
(I didn't want to cough up $145 for the adapter only to find out my car already had one.....)
2001 Base 2.7 - Arctic Silver - 5 speed - Comfort Top -
3-4 Stalk OBC Upgrade - Double DIN Head Unit
Luckyed is offline   Reply With Quote
Old 11-10-2016, 05:31 AM   #10
Engine Oil Filter WIX 51042 | eBay
winterbuoy is offline   Reply With Quote
Old 11-10-2016, 05:35 AM   #11
steved0x's Avatar
Peek under the car, and if the oil filter looks all plastic like, like below, you have the OEM canister filter.
(from this article: Porsche Boxster Oil Change | 986 / 987 (1997-08) | Pelican Parts Technical Article )
If you peek under and see a "regular" metal oil filter with brand names and printing on it, you have a spin on adapter. Also your magnet test is probably a good one too.
You are in Jax, right? If you wanted to come over sometime we could install your spin on adapter and do the first oil change together, I've got all the jacks, tools, etc. Once you do it the first time you will be all set for next time
Old 11-10-2016, 07:29 AM   #12
Luckyed
Luckyed's Avatar
[QUOTE
You are in Jax, right? [/QUOTE]
No, I'm actually down in Port Saint Lucie.
I think we also looked at the geography before when I did my rear control arms.
I appreciate the offer though.
It's always great to know someone is out there willing to help out.
I take it the spin on adapter install is pretty straight forward?
Old 11-10-2016, 08:12 AM   #13
steved0x's Avatar
Port St Lucie - That's right, I remember now.
Yeah the install of the spin on adapter is really easy.
Add oil to the two O-rings - the bigger one on the outside that is obvious, and there is a smaller one on the inside at the top. that is kind of hidden
Then just thread it on, and then torque it to spec (25 Nm - 18 Ft/Lbs). I think the newer ones you can just use a big socket (26mm), the older ones like mine come with a tool that you place on the bottom and then use the socket on that.
Then just thread on the oil filter using regular spin on oil filter technique, oil the gasket, spin it on, when it gets snug go 1 additional turn etc...
When you go to change the oil once the spin on adapter is installed, you can just watch to ensure it does not spin loose with the filter. Mine has never moved after several oil changes.
