Old 10-18-2016, 10:26 PM   #1
Inside Door Handle slack, loose, adjustment?
The inside door handle of my Boxster is slack and drops a little. It can be moved about 1/4" before the tension zone where pulling on it opened the door lock. Because of the drop, the car thinks I am pulling open the handle so sometimes I have to push in the handle to remove the key, I have to push in the handle to close the doors, and the door doesn't close with the remote (since the door lock is dropping).
Is there a way to adjust the door lock so that the slack is taken up?
01 Boxster S 6Spd, Speed Yellow w/84k miles. | 991.1 911 C2 7spd Manual | 01 996 C2 -6spd - Green Machine - My baby | 997.2 C2S 6spd | 2x 01 Boxster base
professorman is offline   Reply With Quote
