This has happened to several of us...best part it is usually easy to fix. There is a spring that holds back pressure on the handle, usually the hook on the end of the spring breaks off and ....POP no tension. I simply took a set of needle nose pliers and bent a new look and hooked it on....that was over a year ago and all is still well...1/3 banana job......easy peasy
