Old 10-24-2016, 03:59 PM   #1
Ho2S heater short to ground
Hello
Bought a OBD2 scanner and downloaded the torque app for android
Got a P117 error
Was directed to Volkswagon Powertrain Manufacturer Controlled DTC
Heated oxygen sensor (HO2S)heater short to ground
Bank 1 Sensor 2
I checked the vacuum and it was steady between 18.6 and 20.6 when I revved it.
Can anyone tell me if this is actually an O2 sensor or a vacuum leak?
Also what side would this be on?
I found all 4 O2 Sensors on my 2001 Boxster
1 is on the manifold 1 is located along exhaust pipe
Mike
mike914 is offline   Reply With Quote
Old 10-24-2016, 04:45 PM   #2
P0117 Engine Temperature Sensor - Below Lower Limit
This is for the engine coolant temp sensor, not the O2 sensors. And not a vacuum leak.
Either the sensor is faulty or the wiring.
The coolant temperature sensor is located on the driver's side of the engine near the cylinder head.
Old 10-24-2016, 04:48 PM   #3
Here is a listing of Porsche specific codes: http://986forum.com/forums/general-discussions/10841-cel-codes.html
Old 10-24-2016, 04:54 PM   #4
Looking through the codes, do you think that you may have got a P1117 and had a typo in your original post?
P1117 Oxygen Sensor Heating 1 After Catalytic Converter - Below Lower Limit
Old 10-24-2016, 04:57 PM   #5
Hello Everyone
You are correct I typed the wrong error
The error I got was P1117DTC
P1117 Volkswagen
Heated Oxygen Sensor HO2S Heater short to ground
Bank1 Sensor 2
Wiring short to ground
Is this the one past the cat?
Which side would it be please?
Mike
Old 10-24-2016, 04:59 PM   #6
If it is indeed P1117, then this link might help: https://sites.google.com/site/mikefocke2/oxygensensors
Old 10-24-2016, 05:01 PM   #7
Passenger side, after the cat.
Originally Posted by mike914 View Post
Hello Everyone
Mike
Old 10-24-2016, 05:11 PM   #8
O2 sensor
Thanks Thstone
I will buy the O2 sensor
Old 10-24-2016, 05:16 PM   #9
Some owners will swap the right and left sensors to see if the problem follows the same sensor...
