Old 10-29-2016, 07:59 AM   #41
joekluger's Avatar
The electric box on top of the front of the engine circled in red. i have no power there. I rebuilt the engine and maybe i did not connect the power correctly when i reinstalled. Should it have constant power? its connected to the starter and alternator.
joekluger is offline   Reply With Quote
Old 10-29-2016, 08:21 AM   #42
Originally Posted by p3230 View Post
But the car starts and runs I try to read the codes with the durametric and nothing shows up anymore. I had code 60 and 47 before but now nothing I replaced the ignition switch and it didn't change a thing. So that's why I think it's something with the key and the CLU.
The only "programming" it could possibly need would be adding a key to it. If your key was not programmed in the CLU, your car wouldn't start. Stop spreading false/bad info, please. When your misconceptions affect only you, that's fine. When you try to spread those misconceptions, you are affecting others by wasting their time and money.
Old 10-29-2016, 08:30 AM   #43
p3230's Avatar
Who died and made you god?
Frank
p3230 is offline   Reply With Quote
Old 10-29-2016, 09:22 AM   #44
joekluger's Avatar
Guys .. any help??
Old 10-29-2016, 04:25 PM   #45
Is this car a tiptronic??? If so check the trans selector cable above the intake. If it is too far to the left it is misaligned. It should be in a bracket to keep it in alignment to allow starting. Ask me how I know... It happened to me today and I found this thread. Took off the engine cover and moved the cable to the right, it started right up !!!!
2001 Base with 2002 3.2 DIY swap 97 "short shift" tip "Joe Toth" aerodynamics, Z top, painted headlights.
2001 Boxster 5 speed
Turbodad is offline   Reply With Quote
Old 10-29-2016, 10:54 PM   #46
I'm an engineer trying to use my expertise in electronics to help the OP, as I've done here for years, and your ill informed posts are detrimental.
In case you missed it, I was also trying to help you with your CLU issue. Not anymore, though.
Old 10-30-2016, 04:21 PM   #47
joekluger's Avatar
starter issue is resolved. when i cleaned the power distributor i forgot to attach the main cable that went to the engine... hence no power to the starter. working now. i did send the immobilizer out to get it checked.
Old 11-04-2016, 01:38 PM   #48
joekluger's Avatar
ECU and immobilizer tested good. Was told its a wiring problem in the car.. but where to look?
Old 11-05-2016, 08:19 AM   #49
joekluger's Avatar
Can someone help or if i can get a copy of the 2000 boxsters wiring diagram...
Old 11-07-2016, 06:27 AM   #50
p3230's Avatar
If you PM me your email address I can scan the electrical part of the Bentley manual and send it to you.
Frank
