Old 10-23-2016, 07:29 PM   #1
Can I drive with passenger seat removed?
Hey all, my poor 987 is currently recovering from a bit of flooding under the passenger seat, caused by a clogged drain. I decided to remove the passenger seat so I could pull up the carpet and get more airflow to the underside. Prior to unplugging the seat's wiring harness, I disconnected the battery, as I understand that failing to do so will cause the airbag warning light to go on.
My question is, can I reconnect the battery while the seat is still out, and drive the car, or will this cause the airbag light to go on? I suspect it will, but I figure there's a chance it senses the state of the connector when the battery is connected.
Cheers,
Jon
ImInHeavenInMy987 is offline   Reply With Quote
Old 10-24-2016, 07:40 AM   #2
This will trigger the airbag light.
Old 10-24-2016, 01:27 PM   #3
Thanks particlewave, guess I'm parked 'til she dries out
Old 10-24-2016, 02:03 PM   #4
Leave the carpet out and put your seat back in for now. It's only 4 bolts.
