Old 10-13-2016, 12:55 PM   #1
JayG's Avatar
Brake Bleeder Screw size
One of my bleeder screws needs to be replaced as it is rounding off
Does anyone know what size they are?
The Porsche ones are $27 a pair and generic ones run a buck or 2 each
Old 10-13-2016, 01:53 PM   #2
steved0x's Avatar
According to here, it maps to Speed Bleeder 1010S
101 Projects for Your Porsche Boxster: Project 48: Bleeding Brakes Parts
Which is M10x1.0 with a length of 31.35 MM
Speed Bleeder Sizes
I'm about to have to do this as well as one of mine is weeping even after it is tightened down all the way. Let us know what you get and how it works out.
Steve
Old 10-13-2016, 03:39 PM   #3
JayG's Avatar
Speed Bleeder Sizes
Steve
Can you use a slightly longer one, 33 mm length?
Old 10-13-2016, 04:28 PM   #4
steved0x's Avatar
I don't see how 1.x mm could cause any trouble, unless it somehow sticks down too far. An extra few mm on the nipple part is no worries. Which one did you find?
Old 10-13-2016, 04:43 PM   #5
JayG's Avatar
Maybe someone can chime in, but I believe that the bleeders seal by seating all the way in, so a longer one would stick out the top a little.
I guess I will have to remove one and see
Gonna have to wait until next week after I get back from the track
Old 10-13-2016, 04:59 PM   #6
steved0x's Avatar
That's exactly what I think too...
Old 10-13-2016, 06:37 PM   #7
JayG's Avatar
Looks like Napa has them for around $2.00
Ill pick on up and see how it works
Old 10-27-2016, 12:53 PM   #8
steved0x's Avatar
Here's the one you need, it is made of titanium and weighs only half of the OEM part so ti reduces your unsprung weight
https://titanclassics.com/product/brembo-fitting-titanium-m8-bleed-screw-2gm-98-8249-20-copy/
Old 10-27-2016, 03:09 PM   #9
Great find because stainless ones are at least this price. Thanks for sharing.
These seem cheap?
http://www.ebay.com/itm/4-xStainless-Steel-Bleed-Nipple-Screws-M10x1-0-Brembo-Caliper-Subaru-STI-WRX-EVO-/291771838907?hash=item43eef4f1bb:gAQAAOSwYGFU0tJ s&vxp=mtr
or
http://www.ebay.com/itm/10MM-M10-x-1mm-Motorcycle-Bike-Brake-Braking-Caliper-Bleed-Screw-Nipple-Dust-Cap-/401140616177?hash=item5d65d80bf1:g:8WIAAOSwMNxXaSQ 6&vxp=mtr
Gelbster is online now   Reply With Quote
Old 10-28-2016, 06:38 AM   #10
mikesz's Avatar
I believe 10mm. I replaced mine with speed bleeders from Pelican. Remember you will need a pair for each caliper. found this out the hard way. I have the original ones that came off the car. they were in good shape let me know if you want one to replace yours you can have it. PM me if you want me to send to you
99 Porsche Boxster
Old 11-04-2016, 09:31 AM   #11
steved0x's Avatar
I just got a set of the OEM Brembo bleeders and I would be happy to take any measurements that you needed me to take to see how they compare with the ones from NAPA.
Old 11-04-2016, 09:52 AM   #12
JayG's Avatar
I just got a set of the Brembo ones that Gelbster posted the link for
Thanks in any case
Going to be replacing my brake lines, the bad bleeder screw and doing a full flush this weekend prior to heading to the track next weekend
Old 11-04-2016, 10:15 AM   #13
steved0x's Avatar
Have a great weekend! And... more videos! That is the only way I can experience the California tracks outside of Forza.
Old 11-05-2016, 03:55 AM   #14
I believe the size is M10 x 1 (pitch) and it is 31.35mm long.
For those of us who have sheared off a stuck nipple and couldn't get the remains out I came across this on Ebay UK which includes a 11mm drill, an M12 x 1 thread tap and a M12 bleed nipple. If you already have an M12 x 1 thread tap then the bleed nipple is available on its own.
M12 X 1.0 Repair Kit with Stainless Steel Bleed Nipple Screw for Brake Calipers | eBay
I can also confirm what I read on a different thread that welding a washer over the broken nipple and either building up the centre of the washer with plenty of weld to get something to grip or then welding a nut to the washer worked for me. I think the heat from the welder helps a lot and the washer protects the caliper body.
RichRobby is offline   Reply With Quote
Old 11-05-2016, 08:04 AM   #15
JayG's Avatar
good ideas
while the length is 31.35 mm, how exactly is that measured???
Old 11-07-2016, 11:09 AM   #16
JayG's Avatar
So I received the bleeders Gelbster noted
4 xStainless Steel Bleed Nipple Screws M10x1.0 Brembo Caliper Subaru STI WRX EVO | eBay
They are a little different than my factory ones
One thing I noticed is the point on the factory one is slightly flatter than the Brembo ones
The other thing is the factory ones use an 11mm wrench and the Brembo is 10mm
Not a big deal in any case
I did install one and it seems to work fine
YMMV
Old 11-07-2016, 11:26 AM   #17
911monty's Avatar
Looks like from your pic that you are losing about 2 threads of engagement with the Brembo bleeder. I say this because if you look at the depth from the nose to the threads the Brembo is approx 2mm longer.
Old 11-08-2016, 12:15 AM   #18
Strange
Contrary to what I said 1 couple of posts up I have now measured one of mine and is is only 29mm ( I assumed it was original but maybe not) and it is an 11mm spanner fit!
Old 11-08-2016, 09:25 AM   #19
A vital (literally) measurement is the angle and major diameter of the cone at the end of the bleed nipple. The angle must be exactly the same as the Factory part.
Usually the angle is 90 degrees but who knows if there are variations.
I suggest the cone angle of the replacement bleed nipples need to be very precisely measured and compared to the original - assuming the original is correct !
Of nerdy interest is that the seat of the caliper will have a slightly different angle to the bleed nipple. In theory this produces a very small concentric sealing surface with very high pressure from tightening the threads. Seems counter-intuitive but it has worked this way for many decades.
Old 11-14-2016, 02:42 PM   #20
JayG's Avatar
Here you go.
It was a great weekend at Buttonwillow. Near perfect weather.
Set a new club track record for my class :dance:
https://youtu.be/e6S42XLrt6k
