10-06-2016, 11:01 AM
#1
Artist, 986S tinkerer
Pulling a dent.
So any suggestions on how to pull this dent on my rocker panel ?
10-06-2016, 11:13 AM
#2
Find a good paintless dent removal service. Even if they can't get in behind they may at least be able to get most of it out.
I just had a PDR guy pull a nasty dent out of a stainless steel refrigerator without removing the panel. I have to look really close to see where it was.
Good luck.
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
10-10-2016, 06:22 AM
#3
Luckyed
I was told that the steel in that part of the car is too thick to "pull"
I had the dent in mine (which also involved the mudflap) repaired at a local body shop for less than $400
Check out the 2 photos in the next post:
2001 Base 2.7 - Arctic Silver - 5 speed - Comfort Top -
3-4 Stalk OBC Upgrade - Double DIN Head Unit
10-10-2016, 06:26 AM
#4
Luckyed
10-10-2016, 02:22 PM
#5
I noticed that there was paint missing in the dent so pdr is not really appropriate. Figured I would DIY since it is on the bottom of the rocker and hardly visible unless you are lying down or if seen from a distance at a low angle. Hence the query.
10-10-2016, 02:32 PM
#6
You could get a dent puller (slide hammer with a screw on the end) which will require a lot of work to get it pulled out without stretching the steel or, a can of body filler and some sand paper then have it painted. If you choose the body filler, make sure you rough up the surface so the filler has something to stick to. Body filler isn't a bad thing, so give it some thought.
10-10-2016, 02:35 PM
#7
Might be a good excuse to fit aero side skirts & just hide the dent.
10-10-2016, 02:58 PM
#8
LEJ, this is what I am considering.
Santafe, yes, I was considering this and I like the look, but since I'm putting the car up for sale, it's not worth the expense at this point.
10-10-2016, 06:51 PM
#9
Project Addicted
Using a sheet metal screw and slide hammer!! What are you a bunch of savages?? A PDR guy might be able to get in behind it and push it out. Other than that leave it.
______
Jon
1966 912, 1976 911
1986 944, 2000 Boxster
10-10-2016, 07:26 PM
#10
heat it up with a heat gun, very hot but not as hot to damage/blister the paint then hit it with a can of compressed air upside down so is spraying cold liquid, or almost frozen water and it will straighten by itself, if it does not completely fix it, repeat. not done it myself but seen it done and it appears to work in some cases
