You could get a dent puller (slide hammer with a screw on the end) which will require a lot of work to get it pulled out without stretching the steel or, a can of body filler and some sand paper then have it painted. If you choose the body filler, make sure you rough up the surface so the filler has something to stick to. Body filler isn't a bad thing, so give it some thought.
