Old 09-26-2016, 12:05 AM   #5
madmodz's Avatar
If you let a mechanic work on it, I would check that your coils are fully connected. The rubber covers secure the connector good and it's easy not to fully push the connector to lock.
I would do the same thing with the fuel injector plugs. If it doesn't fix your problems it's easy to mix up vacuum hoses. That was my issue.
madmodz is offline   Reply With Quote
