Old 09-11-2016, 03:51 PM   #1
Shacky
Air Bag Light After Cleaning Radiators
Had local shop do the radiator clean out. Now my air bag light is on.
Any suggestions other than bringing it back which I will do.
shacky is offline   Reply With Quote
Old 09-11-2016, 05:20 PM   #2
BirdDog's Avatar
That's kind of weird. Did they disconnect your battery or something? In my experience that can set an airbag light. You can turn it off if you have a Durametric cable. If not, get them to do it.
2001 Boxster S - Speed Yellow, Black Leather, Tiptronic, Jake Raby rebuilt 3.2 with IMS Solution
BirdDog is offline   Reply With Quote
Old 09-12-2016, 12:59 AM   #3
Maybe a stupid question...
Will the airbags deploy even if the airbag light is on?
In my case I disconnected the wiring plug to the seat belt reel and triggered the warning and haven't yet been able to reset it.
RichRobby is offline   Reply With Quote
Old 09-21-2016, 03:21 PM   #4
madmodz's Avatar
No, it won't deploy till you clear the code,
madmodz is offline   Reply With Quote
Old 09-12-2016, 07:41 AM   #5
I managed to clear my airbag light with an OBDII scanner. The scanner must have airbag support.
Note: scanner will only clear a tripped code, if other issue exists the fault can reappear.
In my case I had disconnected airbag, which tripped the fault after reconnecting airbag.
1998 Boxster - Ocean Blue Metallic
1999 Porsche 911 - Basalt Black
Lexky is offline   Reply With Quote
Old 09-13-2016, 07:15 AM   #6
Interesting
I tried this cheap version (only about £10 GBP) and it doesn't find the error, even though it says it should.
www.amazon.co.uk/gp/product/B01AC7I7BO
Do you know what one you successfully used?
Old 09-21-2016, 03:11 PM   #7
Shacky
My mechanic said he has "all the software" to check German vars. Is there something I can point him to specifically to get rid of my air bag light?
Old 09-22-2016, 12:32 PM   #8
stelan's Avatar
Lexky, what scanner do you have?
stelan is offline   Reply With Quote
