Originally Posted by Lexky
I managed to clear my airbag light with an OBDII scanner. The scanner must have airbag support.
Note: scanner will only clear a tripped code, if other issue exists the fault can reappear.
In my case I had disconnected airbag, which tripped the fault after reconnecting airbag.
Lexky, what scanner do you have?
