Old 08-02-2016, 06:10 AM   #1
CrisZenithBlue's Avatar
"crunchy" window, need opinions
my window just started doing this:
https://www.youtube.com/watch?v=RbFM9a13MKk
it sounds like it's catching on something, maybe the regulator cables?
note when it goes up than drops more than a palm on its own. is that the safety mechanism thinking it's hitting something or microswitch?
when i push down hard on the window there seems to be some slack in the regulator cables. that's my main suspect i just wanted some opinions in case anyone else had this happen to them, i dont want to open the door twice, i rather buy the regulator and replace in one go. this regulator was replaced by me a year ago with zero issues until now but i guess they are still crappy.
thanks,
Cristian
CrisZenithBlue is offline   Reply With Quote
Old 08-02-2016, 09:33 AM   #2
1999 base
Meir's Avatar
thanks,
Cristian
you need new regulator my friend.
just replaced both on my c2 with only 37K miles on the clock
Old 08-02-2016, 09:50 AM   #3
well.. that regulator lasted me a year
it's not so much about the money but the pain in the A$$ to replace it. not hard but takes time, maybe the second time around i'll be faster.
thank you sir!
Old 08-02-2016, 07:24 PM   #4
1997 Tip, 2018 Macan
rexcramer's Avatar
I know your pain. I had the cable come off the wheel and wedge in between the steel and the wheel. I had installed it about 3 months prior. I was able to pull it apart and re-string it and it has been working for quite awhile now. Unfortunately, I am starting to get pretty good at it. I have had both doors apart twice. These pliers really make it easier to get the door cards off. And the OEM regulators are expensive.
Panel Clip Pliers
