Old 07-26-2016, 04:48 PM   #1
Muskoka Minute's Avatar
my 1st Oil Change done and I found bits
Evening guys
I did my 1st oil. Hangers today and found 3-4 little pc of what looks like aluminum.
It looks like the the foil that is on top of the oil container but much thinner. Is thi a possibility?
It is not metal as it does not stick to the magnet.
Other than that everything looks great!
The oil l nice a clean.
Should I be in panic mode?
Neither me or my mechanic can figure out where it can from.
All suggestions an comments welcome......
Cheers
Bart
My Beast 2004 Boxster SE #0174
- 3.8 with all the internal goodies, Under-mount Pulley, IPD Plenum, 996 Intake, Softronic Tune, 987 Factory Sport Exhaust, skid plates, IMS solution, Ohlins R&T, RSS Toe Links, Camber Plates, Michelin Pilot Super Sport on all 4 corners, Alpine Double Din c/w new speakers & amps.
Muskoka Minute is offline   Reply With Quote
Old 07-26-2016, 06:19 PM   #2
1997 Tip, 2018 Macan
rexcramer's Avatar
Can you post a pic of the debris. How many miles?
Old 07-26-2016, 07:52 PM   #3
In the filter or in the pan ?
Check with a magnet
Rinse the debris in gasoline first to determine the true color.
Old 07-26-2016, 08:34 PM   #4
Aluminum won't stick to a magnet. Please post some pic's.
Old 07-27-2016, 08:45 AM   #5
All that means is it's not iron or steel.
All other metals are not magnetic; i.e. aluminum, magnesium, some stainless steels, etc.
It sounds like it is metal, just not magnetic.
Tcar is offline   Reply With Quote
Old 07-27-2016, 08:59 AM   #6
Got to know if it is ferrous or not to start with indicating probable source. Hence magnet +cleaning of the FOM.
For example, bearing debris often looks golden color before you rinse it. Easily mistaken for bronze Babbit bearing debris. But when you rinse it in a solvent it is grey and non-magnetic.
Old 07-27-2016, 10:01 AM   #7
Get a sample of oil analysed. They should be able to tell you what the fragments are.
Sent from my SM-N910F using Tapatalk
Galway is offline   Reply With Quote
