Old 06-26-2016, 07:36 AM   #1
Jay B.'s Avatar
Frunk light
I noticed my frunk light on my 00 S quit working so I replaced the bulb and still no go but all other interior lights work so I'm thinking a blown fuse?? I do not know what fuse is what so before I start pulling fuses out one by one to inspect a blown one does anybody know which fuse is the correct one or a diagram of the fuse box? Thanks!
2000 Boxster S
Jay B. is offline   Reply With Quote
Old 06-26-2016, 07:39 AM   #2
I am my own mechanic....
Timco's Avatar
If just that light I'd say the switch that controls the frunk light is bad. That light is likely not fused by itself.
'08 VW Touareg T-3 wife's car
Old 06-26-2016, 07:52 AM   #3
Jay B.'s Avatar
Hmm, thanks I was kind of wondering if there was more to it then just a fuse. Any idea where the switch is?
2000 Boxster S
Old 06-26-2016, 08:05 AM   #4
Nine8Six's Avatar
Rub those 16 years old and oxidized contacts with abrasive paper and try again. (guessing here)
Not entirely sure about the circuit for this little one but certainly it is not on its own. Meaning other service lights wouldn't function, shall the circuit be the culprit.
Let us know as mine is also fried Haven't tried to replaced it, yet anyway
Old 06-26-2016, 09:54 AM   #5
KevinH1990's Avatar
I had to replace the microswitch on my 00. There is a DYI on Renntech for replacing the frunk micro switch. I think you have to be a registered member to read it, but here's the link:
http://www.renntech.org/forums/tutorials/article/123-front-trunk-microswitch-replacement/
Old 06-29-2016, 06:42 PM   #6
Jay B.'s Avatar
I just wanted to give you fellas an update on my frunk light issue. I read somewhere that the switch was in the hood latch so I took some WD40 silicone and sprayed the hell out of the latch and with a few minutes of soak time and a few cuss words the light came on and now the light works like a champ now. Good ole' german electric !
2000 Boxster S
Old 11-10-2022, 03:43 PM   #7
Thanks. WD-40 worked to fix my frunk light. It also helped the hood to pop up higher.
01 Boxster S 6Spd, Speed Yellow w/84k miles. | 991.1 911 C2 7spd Manual | 01 996 C2 -6spd - Green Machine - My baby | 997.2 C2S 6spd | 2x 01 Boxster base
professorman is offline   Reply With Quote
Old 11-11-2022, 05:50 AM   #8
On the slippery slope
JayG's Avatar
WD-40 while it has some lubricating properties, it is not a lubricant. Use pure silicon
WD-40= Water Displacement 40th try
2004 996 Targa Tip
Instructor - San Diego region
Old 09-20-2025, 11:53 AM   #9
I know this is an old thread but figured I would add some info. The Renntech article is very helpful but as of 2025, the replacement part is closer to $150. I removed the latch and then removed the plastic cover that houses the micro-switch. My micro-switch was fine but there is a plastic cam that presses against the micro-switch and it was sticking a bit. I added white lithium grease to this cam and the metal tongue of the micro-switch - fixed! I have a '98 so the latch has 2 cable pulls (one for the emergency release and the other for the lever release by the driver's sill. There were 2 grommets that helped hold these cables that disintegrated. I found some grommets and shaved off one side to replace these. Sorry - didn't take pictures but it is pretty straightforward.
'98 Boxster 986
'87 911 Carrera Cabriolet
elav is online now   Reply With Quote
