Old 05-30-2016, 02:03 PM   #1
Battery or Fuse Issues?
Hello, I own a 2001 Boxster. The battery was dead after sitting for the winter. I have replaced the battery, and upon trying to start the car, there are no lights working. The only thing that happens is the fan turns on. Could this be a blown fuse when I put the new battery on?
Thanks!
Doctor Chad is offline   Reply With Quote
Old 05-30-2016, 02:47 PM   #2
The voltage of the battery? The post are snug to the cables? The positives and negatives are the same as the battery you removed? Tip or Stick? Wiggled the steering wheel? Clutch in? Neutral or park? The key turns to the accessory position? To the start position? And signs of rodents?
Old 05-30-2016, 05:31 PM   #3
Didn't try the steering wheel. Everything else looks good. No rodents. Before the new battery, the lights would light up and I heard a clicking sound and the windows went up and down about an inch. Now, nothing but the fan blowing and I can turn the headlights on. That's about it. Could I have blown a fuse when I installed the new battery?
Old 05-31-2016, 03:53 PM   #4
Porsche "Purist"
Paul's Avatar
Any chance the immobilizer (under the driver's seat) got wet?
1987 924S. 2002 996TT. PST-2
Old 06-01-2016, 06:24 PM   #5
MWS
When you say fan, heat/AC fan or cooling fan? If AC fan, I had similar situation. Try pulling 20A and 7.5A fuses for heat/AC and see what happens. In my case, it was a short in climate unit.
Old 06-03-2016, 05:46 AM   #6
Thanks. Nothing got wet, as it's been in the garage.
I will try the fuses this weekend. It's the heating/cooling fan.
Tags
2001 , battery , boxtser
