Old 04-25-2016, 05:08 PM   #1
texomawaves's Avatar
Yellow headlight inner lense replacement
Is there a replacement inner lense that would work or anything other than the expensive HID/Litronics? I don't want to do a major modification and rather replace just the inner lense. Is there some kind of inexpensive solution?
Chris Dennis, Plano, Texas
'07 Boxster, arctic silver, Tiptronic, 106k miles, no mods
‘13 Boxster S, black on black, PDK, 27k miles, garage queen
‘66 Mooney M20E, hangar queen
texomawaves is offline   Reply With Quote
Old 04-25-2016, 05:14 PM   #2
Nope. You can open them up and remove them completely. That and projector install is it.
Old 04-25-2016, 06:50 PM   #3
1997 Tip, 2018 Macan
rexcramer's Avatar
Check with Woody, care of 'itsnotanova', he parts out cars and is very reasonable with price and shipping.
Old 04-26-2016, 07:54 AM   #4
thom4782's Avatar
Oxidation of the clear coat that covers the headlight lens often causes yellowing. Before you spend a ton of time and / or money replacing the lens, try a headlight restoration kit or a local headlight restoration service. You've got little to lose. Lens burned from the inside are a completely different issue
Old 04-26-2016, 10:02 AM   #5
He's referring to the inner lens, not the inside of the main lens.
Old 04-26-2016, 12:57 PM   #6
the yellowed (inside) part guys... Perhaps someone can fabricate replacement lenses. Perhaps someone can run down to Hobby Lobby and make one!
Old 04-27-2016, 01:06 PM   #7
BirdDog's Avatar
As far as I know the inner lenses aren't available separately. I have a set of brand new inner lenses that I picked up from someone that did a projector conversion. At the time I planned to use them to replace my burned inner lenses but ended up buying a set of good used headlights instead. I kept the outer rubber seals from my original headlights and I still have those new inner lenses. I'm planning to put them up for sale on the forums in the very near future (I really need to clean out my unused parts).
There was a thread on the forum that detailed how someone replaced the inner lenses. I think you have to heat the headlight to 250 F (wearing gloves!) in order to soften up the sealer enough to get the outer lens off. The outer lens snaps into a groove in the housing and must be pried out.
2001 Boxster S - Speed Yellow, Black Leather, Tiptronic, Jake Raby rebuilt 3.2 with IMS Solution
BirdDog is offline   Reply With Quote
Old 05-01-2016, 08:34 AM   #8
Bird Dog, If you wanted to sell the inner lenses, what would you want for them?
