Originally Posted by thom4782
Oxidation of the clear coat that covers the headlight lens often causes yellowing. Before you spend a ton of time and / or money replacing the lens, try a headlight restoration kit or a local headlight restoration service. You've got little to lose. Lens burned from the inside are a completely different issue
He's referring to the inner lens, not the inside of the main lens.
