Old 04-10-2016, 07:54 AM   #1
Exclamation Porsche Boxster Running Woes
My girlfriend's father recently bought a 2002 Porsche Boxster S and is having issues getting to run properly. The car has 23,xxx miles on it. Since getting it, it has not started happily.
Symptoms-
Takes forever to start and when it does start it misfires on all cylinders-
Codes read Misfire on cylinder 2,4,5,6 and random misfire- that clears up after running for a couple of minutes.
After a couple of minutes I can erase all codes and it will run fine from there on out.
What he has done-
Replaced coils and plugs on each cylinder
Replaced all fuel injectors
Replaced Crank Position Sensor
Had ECU tested
Once warm it starts and runs fine.
TheFonz is offline   Reply With Quote
