Old 03-24-2016, 11:14 AM   #1
Rain entering cabin
I have posted about this problem before but haven't been able to sort the problem.
To recap, I have rain water entering the passenger footwell at the front of the car ( right hand drive) I have poured water down the front drains and this runs out ok, I have put an air line down them to make sure they are not blocked, I have replaced the missing rubber grommets to the drain holes. I have had the door membrane replaced even though the door card was dry, I have re sealed the cabin filter casing and have now run out of ideas.
Is there anything I am missing.
The water is entering from behind the dash but not through the screen, it runs down the bulkhead and onto the carpet. The carpet under the seats always remains dry so it isn't the rear drains.
Fed up and at the moment defeated.
HELP
Walshie is offline   Reply With Quote
Old 03-24-2016, 12:28 PM   #2
Are all the frunk cowl covers properly installed and present? Battery drain working properly? Fuel overflow draining properly?
Old 03-24-2016, 01:03 PM   #3
Ben-Auto-Design
Ben006's Avatar
A/c evaporator drain clogged ?
Porsche Tech in France.
www.benautodesign.fr
1982 928 S Euro
Ben006 is offline   Reply With Quote
Old 03-24-2016, 01:28 PM   #4
[QUOTE=Flavor 987S;488759]Are all the frunk cowl covers properly installed and present? Battery drain working properly? Fuel overflow draining properly?[/UOTE]
Yes all installed properly and all drains clear
Old 03-24-2016, 01:29 PM   #5
No not clogged, and car gets wet when sitting outside the house not being used.
Old 03-24-2016, 01:57 PM   #6
seningen's Avatar
Can you replicate by using a hose? If so I've heard of folks putting dry food coloring in certain areas then doing the hose test and seeing what color water shows up.
Mike
mike@lonestarrpm.com
Old 03-24-2016, 03:44 PM   #7
Pominoz's Avatar
HELP
Are you sure it's not getting in somewhere round the side windows? I had to get my passenger side windows adjusted to stop water getting in past the front edge and running down the inside front of the door.
Boxster Base, 2002 Manual, Black.
LN Single Row Pro IMS retrofit.
Pominoz is offline   Reply With Quote
Old 03-24-2016, 07:13 PM   #8
1997 Tip, 2018 Macan
rexcramer's Avatar
Are both of the door liners in good shape and in place? I am talking about the ones between the metal door and the inner interior panel.
Old 03-24-2016, 07:32 PM   #9
Could the seal around your windshield be the problem?
first boxster is offline   Reply With Quote
Old 03-24-2016, 10:03 PM   #10
Yes both are In good shape, passenger side is new and fitted by porsche
Old 03-24-2016, 10:07 PM   #11
No, I have water tested from below the windshield line, the water drains away ok from the skuttle panel through the drains but some ends up running down the cabin side of the bulkhead at the very front.
Old 03-25-2016, 07:57 AM   #12
I have tried with a hose and also more specific placement of water to try to locate point of entry. When pouring a jug of water in the skuttle tray, it drained down the drain hole but then seeped through where the heater box passes through the bulkhead. I do not know what is the other side of this and how to get to it.
Sent from my D6603 using Tapatalk
Old 03-25-2016, 09:40 AM   #13
More of a truck guy
Just so you know you aren't alone. I get water behind my passenger seat, every time it rains. Drives me bat******************** crazy. Did the hose test, made sure all drains were free and clear, checked seals, and yada yada yada. I finally just gave up, and keep the carpet pulled up behind the seat. If it rains, I keep a small white towel under the carpet. It soaks up the water, and when the weather is nice, I leave the top down during the day and it dries out nicely.
Not the fix your looking for, but I feel your pain!!!!!
Best of luck!
2002 Boxster S 6 Speed
TNT79Bronco is offline   Reply With Quote
Old 03-25-2016, 10:39 AM   #14
texomawaves's Avatar
check the front wheel fender liners... perhaps water splashing up from the tires.
Chris Dennis, Plano, Texas
'07 Boxster, arctic silver, Tiptronic, 106k miles, no mods
‘13 Boxster S, black on black, PDK, 27k miles, garage queen
‘66 Mooney M20E, hangar queen
texomawaves is offline   Reply With Quote
Old 03-25-2016, 10:44 AM   #15
Best of luck!
Thanks, it is very frustrating, I am starting to feel that way. I have bought a storm cover for when the weather is bad.
Old 03-25-2016, 10:45 AM   #16
Unfortunately no, it leaks when standing outside the house not being used.
Old 03-25-2016, 11:08 AM   #17
Walshie, you have probably seen this link already, but sending it along in case you haven't. Mike is a member on this forum. You might try a PM to him.
https://sites.google.com/site/mikefocke2/drainsdiagram
Need_for_speed is offline   Reply With Quote
Old 03-25-2016, 01:05 PM   #18
Hi need for Speed.
From this it looks like there is 4 drains fuel filler, one either side of battery and no 3 that I didn't know about, is this correct
Old 03-25-2016, 02:40 PM   #19
I count 6 total: 2 behind the seats, 2 in front (near battery), fuel and a/c.
Old 03-26-2016, 03:51 AM   #20
Oh ok no 3 on the schematic is the AC drain. I take it this is only a problem if the AC is running and not while it is sitting unused.
