Old 03-22-2016, 02:10 AM   #1
flouese's Avatar
Now what?
As part of my $5,200 repair bill, my slave cylinder was changed out. After 3 weeks of driving, my clutch pedal occasionally fails to return and I have to pull it back up with my toe. This started the other day when I was in my driveway and stalled the car with the pedal depressed. I pulled it back up then looked under the car and saw a few drips of fluid. The car shifts and brakes fine. No problems until this morning.
Do I need to bleed the system to fix this?
99 Boxster base
1966 912 3 gauge
flouese is offline   Reply With Quote
Old 03-22-2016, 04:37 AM   #2
I am my own mechanic....
Timco's Avatar
Air in the line won't cause fluid to escape. I'd want to know exactly what the fluid is.
'08 VW Touareg T-3 wife's car
Old 03-22-2016, 05:25 AM   #3
flouese's Avatar
Since it came from below the slave cylinder, I assume it's hydraulic fluid (brake/clutch).
99 Boxster base
1966 912 3 gauge
Old 03-22-2016, 05:59 AM   #4
Project Addicted
jcslocum's Avatar
There are 2 parts in that system. The master cylinder below your foot and the slave on the trans.
Sounds like a stop at the shop that did the work is needed.
______
Jon
1966 912, 1976 911
1986 944, 2000 Boxster
Old 03-22-2016, 08:41 AM   #5
Perfectlap's Avatar
Check out Pedro's Boxster website. He's in Florida too. Maybe you get his take on your shop.
http://pedrosboard.com/
BORN: March 2000 - FINLAND
Old 03-22-2016, 04:58 PM   #6
Likely the clutch master cylinder. Operates on brake fluid from the brake resovoir.
Deadeye is offline   Reply With Quote
Old 03-22-2016, 05:11 PM   #7
Gotta add that it's not uncommon to have a master fail after replacing the slave....
Don't despair, these are not big repairs compares to what you've already been through.
Old 03-24-2016, 05:57 AM   #8
flouese's Avatar
An update to the continuing saga:
The clutch pedal only fails to return when in reverse. I pulls back easily with the toe of my shoe. Any ideas on a remedy?
99 Boxster base
1966 912 3 gauge
Old 03-24-2016, 06:22 AM   #9
Joe B's Avatar
What did the shop that did the $5,200 worth of repairs say?
Old 03-24-2016, 07:18 AM   #10
flouese's Avatar
Waiting on a call back from them. Hopefully soon.
99 Boxster base
1966 912 3 gauge
