01-23-2016, 02:41 PM
Things to do while Dash Removed?
I'm almost ready to remove my dash for the dye/repair wire... I was thinking, besides the 4th Stalk which i can do with the dash in, what mods or upgrades can I perform while it's out. It will be out for a couple days for the dye.
Sent from my SM-G925T using Tapatalk
-Josh
2001 Porsche 986 Boxster RS2.7 Bi-Turbo
01-23-2016, 02:45 PM
HVAC flap foam removal/replacement.
01-23-2016, 02:47 PM
2002 Boxster S
Speaker upgrade?
2009 Carrera S cabrio
01-23-2016, 03:39 PM
Mechanical or electrical ignition switch replacement.
01-23-2016, 05:59 PM
98 Arctic silver 986
If you want to paint the plastic trim strips that run across the middle of the dash. With the dash out it will be MUCH MUCH easier to remove these. Actually you will most likely be removing these from the dash before the dye job. Either way much easier to get them off and on with the dash out.
01-23-2016, 10:51 PM
Originally Posted by silver-S
Speaker upgrade?
I have MB Quartz in the doors, and dislike the overwhelming sound out of the Alpine Dash Speakers. Even tho they can't handle the power so they sound pretty bad on some notes. I have mine disconnected.
-Josh
01-23-2016, 10:53 PM
Mine are Leather. I have a full Leather interior. Every inch of my dash except... The center vents... And... The red speaker covers are all leather.
-Josh
01-23-2016, 10:54 PM
That's in the center right... And the flap that stops the air from moving through the center? I think I have some sticky foam stuff to seal home windows.
-Josh
01-23-2016, 10:56 PM
With the dash out, it doesn't look like there is much to do, the ignition switch maybe. Mine hasn't given any issues but possibly good idea while it's out
-Josh
01-23-2016, 11:10 PM
There are 4, actually.
01-23-2016, 11:12 PM
Image is broken. I used some to adapt the 01 vent with the 04 dash center face. But I believe I have more
-Josh
01-23-2016, 11:19 PM
I fixed the image...I think. I can see it, anyway.
01-24-2016, 10:51 PM
I'll look at it. Question, when the vents... On the HVaC display aren't active, should any come out of the center?
-Josh
01-26-2016, 01:11 PM
If you wanted to change the horizontal trim strips to, say carbon fiber, aluminum, etc., doing it with the dash out is easiest.
Kent Christensen
Albuquerque
2001 Boxster
2007 GL320 CDI, 2010 CL550
2 BMW motorcycles
01-26-2016, 01:23 PM
1999 base
there are 4 flaps in total, but only 2 (6&11)are covered with the deteriorating foam.
01-31-2016, 12:04 PM
Eh, I just dyed it. But I might if the dye takes longer. I've depleted the city of all the dye lol. So waiting for new order. They only have small bottles  and the dash took a lot. I'm about to order red carbon fiber for the plastic pieces and the center surrounding the tablet/radio. So maybe that will just be the ultimate set off to look bad ass.
I did however locate my wire issue. Despite the previous owner installing a fuse that was higher than it should be, seems the drop top switch is what shorted out while it wasn't connected and luckily is the only damage.
So the rest of the wires are fine. It's just from here over the steering column to the center and to the switch.
I'll probably just cut this wire. The car is permanently hardtop and the only reason I have to open the deck would be to remove the sub enclosure so I could install a switch here. Maybe use the spoiler switch since I wanna move it to a better location.
-Josh
01-31-2016, 01:11 PM
How will you get in to change air filter, top up power steering, etc.?
Kent Christensen
Albuquerque
2001 Boxster
2 BMW motorcycles
01-31-2016, 01:42 PM
Easy, remove the engine cap. With the soft top no longer there, there is no reason for the deck to move really. There is a ton of empty space. The switch is hidden behind the radio anyway.
-Josh
