Old 12-30-2015, 02:57 PM   #1
WillH's Avatar
Hand pump for transmission fill
This is the first time I've needed a pump to fill a tranny. What are you using?
Before dumping the oil I checked the level and it measured about 16mm below the edge so I'm guessing that might have had something to do with the notchy-ness while cold. Quick shifter is in and am looking forward to an improvement in cold performance.
Old 12-30-2015, 03:03 PM   #2
Go and get a cheap drill water pump and adapt the hose ends to a tube. Works great.
Lon Tusler
1999 996, Track Only #996
Everything Jake could upgrade, and more!
ltusler is offline   Reply With Quote
Old 12-30-2015, 03:38 PM   #3
Project Addicted
jcslocum's Avatar
Proper level is about 1mm below the hole.
I was able to get the 1 qt containers up there and with a nozzle on them, squeeze the oil in. No pump needed.
Porsche Boxster Differential / Manual Transmission Fluid Change - 986 / 987 (1997-08) - Pelican Parts Technical Article
______
Jon
1966 912, 1976 911
1986 944, 2000 Boxster
Old 12-30-2015, 03:39 PM   #4
Cheap pump up garden sprayer works also.
rfuerst911sc is online now   Reply With Quote
Old 12-30-2015, 04:05 PM   #5
Chuck W.'s Avatar
Here is what I have used on several cars. Cheap, easy and it works!
Multi-Use Transfer Pump
1995 Porsche C4 Cab
Old 12-30-2015, 04:28 PM   #6
WillH's Avatar
Thanks guys,
Used to buying in gear oil bottles that that come with a nozzle. Generally have no problems and on occasion attach a tube.
Dealer sent the Durmah in litre engine oil containers. Could probably screw around with fittings on the original caps but looking for the easiest way with the least waste/mess.
The responses have been good and I'm sure I'll see the light...
Old 12-30-2015, 04:28 PM   #7
There Is No Substitute.
rick3000's Avatar
Not sure if you have a manual or tiptronic, but if it is a manual, you can use a funnel instead of a pump. I attached 3' of vinyl tubing to the end of a funnel with a heat gun, and poured from the engine bay down into the fill hole. It's a lot easier in my opinion, and cost about $3, but you will need an assistant.
FYI, if you have a manual transmission make sure you use the correct OEM oil. Earlier years use a different oil.
Old 12-30-2015, 04:35 PM   #8
WillH's Avatar
This sounds like a winner. Will have to inlist one of the kids to help
Yep, splurged on the Durmah from the dealer, 51$ cdn per litre from the dealer, thus the problem filling as it came in engine oil bottles.
Old 12-30-2015, 04:59 PM   #9
I use the exact same pump! In fact, I just used it yesterday to replace the trans fluid. Its cheap and it works great.
Old 12-30-2015, 09:49 PM   #10
Pdwight's Avatar
If it's for a manual
It really just dopes not hold that much. I used one of these I purchased at a Auto Zone on the closeout table for 2 bucks
http://contentinfo.autozone.com/znetcs/product-info/en/US/igs/57429/image/2/
Old 01-01-2016, 04:30 PM   #11
The red pump shown is available all over . You will see it for $15. Use a coupon and buy it at Harbor Freight for $5. They are so cheap I have a couple for different fluids.
arthrodriver is offline   Reply With Quote
Old 01-02-2016, 01:35 PM   #12
WillH's Avatar
Well, bought and used the orange pump. Worked ok.
Some fine brass in the old oil, hopefully normal for first change.
