Old 12-22-2015, 07:26 PM   #1
Water pump recommendation
I know search is your friend but couldn't find. Any recommendations for a decent water pump for 00 box s?
ThAnks.
DWBOX2000 is offline   Reply With Quote
Old 12-22-2015, 07:37 PM   #2
Pdwight's Avatar
Lots to read, the general consensus is to stay away from any metal impeller pump.
Old 12-22-2015, 08:24 PM   #3
On the slippery slope
JayG's Avatar
simple
Get a pierburg from warehouse33auto.com
putt rennlist in the coupon code area when checking out and get an additional 10% off
don't forget to order a new gasket and coolant (3 gallons) that you dilute 50/50 with distilled water (walmart $0.88/ gal)
good idea to replace your thermostat while you are in there
also replace the bolts, I had one torque off at 7 ftlbs!
2004 996 Targa Tip
Instructor - San Diego region
Old 12-23-2015, 03:16 AM   #4
Thank you both? Any opinion on the manufacturer whalen vs LN engineering for a thermostat? Might as well swap out while down there.
Old 12-23-2015, 03:18 AM   #5
Wahler? Sorry I think that is it.
Old 12-23-2015, 06:46 AM   #6
Luv2Box's Avatar
Having dealt with third party pumps I recommend OEM only. Even the OEM pumps aren't great but third party failures are more frequent than OEM. The third party pump I used once lasted 2,400 mi. and you'll hear stories similar to mine a lot. I've heard, unconfirmed, that even Porsche are recommending a new pump at 40K miles as a maintenance service.
Luv2Box is offline   Reply With Quote
Old 12-23-2015, 07:11 AM   #7
JayG's Avatar
the Wahler is fine. It is a whole lot less $ than the LN and comes already installed in a housing.
Many also suggest replacing it with the low temp version. Lots of discussion on that.
Pierburg makes the Porsche water pump and the one I received had the Porsche number on it
I don't recall any issues or problem with the Pierburg one
drink whatever kool-aid you prefer
Also if you can, buy or borrow an Airlift for replacing the coolant. You will need a compressor to use it
There are a lot of water pump and DIY threads here as well as DIY on pelican. Do some searching.
2004 996 Targa Tip
Old 12-23-2015, 07:30 AM   #8
Chuck W.'s Avatar
And, and..... consider changing the motor mount while you're in there. It makes changing the water pump easier and they are a maintenance item.
1995 Porsche C4 Cab
Old 12-23-2015, 07:35 AM   #9
steved0x's Avatar
Originally Posted by Chuck W. View Post
And, and..... consider changing the motor mount while your in there. It makes changing the water pump easier and they are a maintenance item.
+1
And makes it easier to tighten the one fiddly bolt on the WP, and with the coolant hoses loosened makes it much easier to get to the motor mount.
Old 12-23-2015, 07:36 AM   #10
Thanks guys. Now do the motor mounts wear out over time or usage. Car has just under 50k.
Old 12-23-2015, 07:46 AM   #11
Porsche9's Avatar
Time ravages the rubber. If it hasn't been replaced yet it likily that it needs to be. Warehouse 33 got it for $174.
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
Old 12-23-2015, 07:54 AM   #12
JayG's Avatar
of if you have access to a ??ton press, you can just buy the insert for a lot less $$
2004 996 Targa Tip
Old 12-23-2015, 08:01 AM   #13
Chuck W.'s Avatar
I changed mine earlier this year when I did the water pump and other items. The Boxster had 26,000 miles on it. Here are some photos of it. Keep in mind the car is a garage queen, it is always in the garage and never driven in the rain. Like others have said, it's the age. Fourteen year old rubber under stress just doesn't hold up.
The part number is 987.375.023.05. It was $138.62 at Sunset Porsche.
1995 Porsche C4 Cab
Old 12-24-2015, 04:12 AM   #14
Fyeganeh's Avatar
This is a side question - but can changing the motor mount effect the stick shift and how hard it is to shift?
I had my clutch done in Oct 2014 and afterwards my shifter was the smoothest ever. Then in Dec 2014 I did the motor mount and I don't remember the timing exactly but for the last year shifting has been tight and hard. I also had the transmission fluid changed somewhere in that time frame.
Fyeganeh is offline   Reply With Quote
Old 12-24-2015, 05:49 AM   #15
What fluid was used? Probably not Porsche OE 75W90 gear lube. Go back to that, and it should improve. Worse on cold mornings?
Motor mounts on a Boxster are more critical for the trans vs a 911 (a 911 actually has trans mounts too) due to the mid engine set-up.
Old 12-24-2015, 06:06 AM   #16
I think you meant to say "OE". OE does not equal OEM. For example:
OE= a Porsche water pump in a Porsche box
OEM= an approved Porsche part manufacturer, like Pierburg, NOT in a Porsche box, may or may not have a Porsche part number.
Third Party= someone who make water pumps, that does NOT supply to the Porsche supply-chain
Heck, even Jake Raby uses and recommends only a Porsche OE water pump.
Whatever you decide, just don't us a pump with a metal impeller, composite only.
Old 12-27-2015, 04:50 PM   #17
I bought a water pump and am trying to plan out my next move. I loosened the belt and the bearing on the existing wp seems very tight, no wobble at all. From the top I can get to all the bolts that are visible. Are the two on the bottom the hardest to get off. 5 on top not so bad, how are the two that need to be accessed from the bottom? Also, how long can I leave my car on jacks. I will probably do over a week. Is that ok?
Old 12-27-2015, 05:04 PM   #18
Luv2Box's Avatar
OEM to me has always meant Original Equipment Manufacturer which in the case of Porsche means it comes in a Porsche box with a Porsche part number on it. It may (and most likely is)be made by a third party company but is the authorized Porsche replacement part. I don't ever recall buying a Porsche replacement part (OEM) that didn't have a Porsche number on it.
Old 12-27-2015, 06:40 PM   #19
JayG's Avatar
Raby doe not care what parts cost. When you have maybe $10k+ profit in a engine, it doesn't matter that much
2004 996 Targa Tip
Old 12-28-2015, 05:37 AM   #20
Your first statement is false. I don't know about your second statement, because I am not privy to Jake's finances and margin structure, and I doubt you are too.
Read his old threads about water pumps. What I remember from years ago; he recommends Porsche OE water pumps, no after markets stuff, no metal impellers, no OEM stuff, only pumps with Porsche part numbers in a Porsche box. He developed or had one developed a few years ago, Very stout & robust. But, it didn't sell. Expensive. So he went back to OE Porsche, and recommends changing about every 4 years as preventive maintenance.
*All this was for the 986/996 and first generation 987/997. Wonder how this will play out for the 987.2/997.2 and the newest 981 and 991 with the DI and 9A1 motors??
