Old 12-14-2015, 04:25 AM   #1
jim_hoyland's Avatar
CEL P0410 after AOS replacement...Connected ?
I just had my indy replace the AOS and two days later the CEL P0410 appears, it says Secondary Air Injection problem on my OBDC diagnostic.
Is there something about the AOS replacement that is related to getting this CEL ?
jim_hoyland is offline   Reply With Quote
Old 12-14-2015, 06:31 AM   #2
It's possible that a vacuum line got disconnected. The same thing happened to me when I replaced my power steering pump. In my case, the tiny check valve attached to one of the rubber sleeves came off. Surprisingly, didn't affect drivability but did set the air injection code every 2nd or 3rd time I started the car after resetting the code.
newBgeek is online now   Reply With Quote
Old 12-14-2015, 02:30 PM   #3
Got it fixed.....not serious
Just picked the car up. It was a three way hose connector. It was brittle, broken, and the hose fell away. CELs gone bye-bye.
It's interesting that this is fairly common after replacing the AOS.
Old 12-14-2015, 08:48 PM   #4
Talking
There is a vacuum line that runs across the engine and acts like a trip-wire. It's easy to trip over when you're yanking something out of the engine. I must have tripped over it while yanking out my power steering pump. The vacuum line is connected to the t-connector. The other 2 connections are fairly short. When you trip over it, something is going to give. In my case it was the check-valve which is also connected to the T. In your case, the T itself broke.
This is one of the reasons I like to work on my own cars. So when there is a screw-up, I know who to blame!
