Old 12-14-2015, 06:31 AM   #2
newBgeek
Originally Posted by jim_hoyland View Post
I just had my indy replace the AOS and two days later the CEL P0410 appears, it says Secondary Air Injection problem on my OBDC diagnostic.
Is there something about the AOS replacement that is related to getting this CEL ?
It's possible that a vacuum line got disconnected. The same thing happened to me when I replaced my power steering pump. In my case, the tiny check valve attached to one of the rubber sleeves came off. Surprisingly, didn't affect drivability but did set the air injection code every 2nd or 3rd time I started the car after resetting the code.
newBgeek is online now   Reply With Quote
